06-29-2002, 03:12 | #1 (permalink) |
Freak Poster Join Date: Jun 2002
Member: 13034 Status: Offline Thanks Meter: 1 | How to change menu graphic on newer models/firmware? Fgraphic doesn't work... |
06-29-2002, 04:38 | #4 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Leiria, PT & *******, CN
Member: 3756 Status: Offline Thanks Meter: 5 | Well, you have to adjust it... so you can see it correctly... Not that i have many experience doing it... but that is what i would do... Best Regards and good luck. |
06-29-2002, 21:59 | #7 (permalink) |
Junior Member Join Date: Dec 2001 Location: Athens, Greece
Member: 8178 Status: Offline Thanks Meter: 0 | FlashGraphic 2.0 I have a beta version of Flash Graphic 2.0 and yes it find out all the availiable images for every phone automatically! (It has one limitation though: it is not working in 5210 and 3410, they are different from the others but the creator told me that it will be fixed in the final) Just be patient |
07-01-2002, 23:43 | #9 (permalink) |
Insane Poster Join Date: Jan 2002 Location: origin Sofia, Bulgaria
Member: 9039 Status: Offline Thanks Meter: 0 | well, good morning my program finds automaticly for months the graphics... problem is the checksummcorrection in newer versions - you will have no signal, so it's no use to change them! ie look for NokHex 1.00 ... GreetZ! |
07-02-2002, 03:21 | #10 (permalink) |
Major Poster Join Date: Feb 2002 Location: NL
Member: 9481 Status: Offline Thanks Meter: 0 | Hi, I want to respond to this. >> you will have no signal, so it's no use to change them! This problem is only known for 3310-503/513, 3330-430/450. I did logoos on 331x-545/547/555 with Nokhex100. It has only different layout at the last logoos since there is now picture editor. After modifications, use nFree1.2 to correct the mcu checksums. (sorry Mr. Bleed, U have problem with 2nd mcu check) Then use ppm manager for the flash checksum, use only full flash (mcu&ppm). Flash it, authorise faid. Good Luck NokDoc |
07-02-2002, 03:31 | #11 (permalink) | |
Member: 9039 Status: Offline Thanks Meter: 0 | Quote:
This isn't the problem, to writte the checksumm 4 bytes before the ppm end Yes it's on 33xx only atm... | |
07-02-2002, 04:58 | #12 (permalink) |
Member: 13034 Status: Offline Thanks Meter: 1 | bleedr: I have actually used you program before... it is actually the netmonitor picture i wanted to change - which your program thinks is the "picture editor" menu. But i'm about to change the messages animasjon now, but when i load a .bmp, nothing happens... Isn't the picture supposed to load and be displayed as hex? why doesn't anything happen? is there any other program i can convert my bmp to hex, so that i can just paste the code into you program? |
07-02-2002, 05:16 | #13 (permalink) |
Member: 9039 Status: Offline Thanks Meter: 0 | hi man! well 1st - when i released my prog there wasnt the 3315, nor the picture menu - you would be able to find the net monitor on some stafe after the pciture one! 2nd when u edit it u wont get network, no matter if u use mine or other progs - no 1 knows, or says how these new verison calculate the checksumm :/ 3. my prog support only NokHex BMP format - just save a picture with nokhex and open it in a picture editor, u'll see how ur pic gotta be, sorry for that but i want a seperate standart for my prog and i've ocded all the ****ty bmp stuf myself, not a ready plugin or kinda of this microsoft ****ty boxes GreetZ! |
How To Unlock Menu Code On V3? | denard | Ultima Box Light | 3 | 07-31-2007 21:02 |
K500i how to change menu language withaut using JOYSTICK | crossings | Sony Ericsson | 1 | 03-10-2006 11:55 |
K500i how to change menu language withaut using JOYSTICK | crossings | Sony Ericsson Hardware Repair | 0 | 03-09-2006 16:54 |
How to change menu item order | TurboX | Sim Cloning and Scaning | 4 | 06-10-2003 07:26 |
How to change menu language to chinese or other text? | doraemon | Sim Cloning and Scaning | 1 | 11-27-2002 06:44 |
