01-04-2001, 12:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | Let's Collect info about Contact Service Here . i still can't get the correct answer for my question about contact service . - if dejan will help in repairing contact service , So .. sure it won't repair all contact service reasons !!... SO .. dejan will help in which error which its the reason of contact service in phone , Dejan said flasher will help in BAD FLASH CHK and BAD PPM CHK .. 1 - just ??? or there is more than this errors . 2 - now i got phone any model with contact service in my hand OK ? .. what to do step by step to be sure that its contact service SOFTWARE Not HARDWARE .. then to know whats the error ??? " wintelsa " ?? .. then to know if i can repair using flasher or not " put same full flash from another working phone " .. 3 - somtimes i read phone " contact service in it " i get all locks open .. " is that hardware error ??? " sometimes , all locks close .. ??? 4 - there is alot of other errors not contact service " sw bugs " some phones hang-up after get network and some hangs when press menu .. etc " can repair too " ? - i tried too many phones write full flash from working phone and no success !! - some times when get eeprom+flash and write back .. phone works but sure without network and imei changed .. so most of errors in eeprom . anyone have experience in this .. tell us here plzzzz .. plz all tell us here your results in contact service repairing . Regards |
01-04-2001, 13:33 | #2 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Hope this will help... Contact Service is almost always due to bad checksum in EEPROM. If Flash is bad, the phone wont even power on! So most likely your problem is only in EEPROM. That is if you did not accidentaly drop your phone from a high place because some chips might have lost contact to board. For hardware problems, just put Soldering Flux (not soldering paste) to the Chip and heat it with SMD Rework Station (hot air). Be sure to use very low air so small resistors or capacitors beside Chip wont be ****n away. For 3310, almost all the time the problem is in EEPROM checksum only. There is not yet a software for 3310 EEPROM fixing, but if you know where checksum is, then it will be easy to do it manually. To know where 1st checksum is, read entire flash from working phone at 00200000 to 00400000 and save it as backup. Now change the security of the phone then read the flash again at same address. You will see changes of course, look for the security code in the form of 31 32 33 34 35 for 12345... Now look for the nearest byte that also changed and that is 1st checksum. Do not mind the other changes. Checksum is 2 bytes if I am not mistaken... Replace the checksum with correct one (you must know how to calculate of course). And write flash again to phone... All should be well... Best Regards, X-Shadow |
01-04-2001, 18:20 | #3 (permalink) |
Crazy Poster Join Date: Dec 2000 Location: Sweden
Member: 2806 Status: Offline Thanks Meter: 0 | Ok then the first thing to find the chksum shouldn`t be to difficult but calculating a new chksum ? Does anybody know how and is it possible to do this manually without a sw ? |
01-06-2001, 06:53 | #4 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | Hi X-shadow ... ur the best always . and u too friends .. this is really useful info for me .. so .. i have 3310 contact service now 2 phones and 1 phone with hang-up when power-on .. can i send u the eeprom files and calcualte the checksum for me .. cuz i dunno how to do it !! P.S : i tried get full backup of flash from fatum but the file contain eeprom too cuz imei changed after flash .. its from 200000 to 400000 .. so what the eeprom start and end address in 3310 .. from 300000 to 400000 or !!!! ok the 3 phones i tried with any NSE-? in wintesla and i got this results in self-tests 1 - 3310 phone - contact service test number 1-MCU ROM CHECKSUM (p)FAILED 2-PPM CHECKSUM (P)notvalid 2 - 3310 phone - contact service PPM CHECKSUM FILED 3 - 3310 - hang-up ALL PASSED .! .. x-shadow , liki , friends ??? can i send dump of eeprom to anyone here and help me with this contact service ? Thank u V.Much. REgards |
01-07-2001, 10:25 | #5 (permalink) |
Member: 871 Status: Offline Thanks Meter: 602 | Try this with 3310, but only for checksum block 1... This is tested only on 8210 and 8850... I dont have 3310 right now to experiment with because all is sold out!!! [Contact Service Repairer for 8210, 8850 by X-Shadow] [December 23, 2000 - - email: [email protected] ] * This will only repair 'Contact Service' due to bad Checksum in EEPROM * This will only repair Checksum Block 1 * If you are not sure about what you are doing, make a backup of the entire flash first of your phone by reading address 00200000 to 00400000 and the put readed file in a safe place. * I am not liable to any damages that may happen to your phone while doing this. If you dont know what you are doing, then might as well stick to sending Logos and Ringertones... 1. Read Address 003d0000 to 003e0000 using Dejan Flasher 2. Run Hackman 3.21 and open Flash.out 3. Delete first 38 bytes or address 0000:0000 upto 0000:0025 4. Save file as EEPROM.bin 5. Run Bartek Contact Service Repairer 1.0 6. Click 3210 in Phone type and open file EEPROM.bin (You must see correct IMEI at 'Displayed IMEI' otherwise you are doing something wrong) 7. Look at 'Counted' Checksum and take note of the 2 bytes Example: Counted: [8F (143dec)] [33 (51dec)] * first byte is 8F * second byte is 33 8. Go back to Hackman 3.21 and open Flash.out 9. Edit address 0000:0144 and put the first byte from Bartek Soft 10. Edit address 0000:0145 and put the second byte from Bartek Soft 11. Save file as Flash.fls and put file in 'c:\nk_files' directory 12. Write to Address 003d0000 with file Flash.fls using Dejan Flasher |
LET'S COLLECT INFORMATIONS ABOUT SAMSUNG SERVICE MANUALS | gsnbhagawan | Samsung Flashers, Software, Firmware. | 17 | 12-15-2008 10:36 |
Usefull info about NOKIA tool - HERE! | Multi-box TEAM | Multi-Box | 52 | 11-28-2008 22:37 |
LET'S COLLECT INFORMATIONS ABOUT ALCATEL SERVICE MANUALS!!! | gsnbhagawan | Alcatel & TCL Old Models | 0 | 03-20-2001 10:31 |
LET'S COLLECT INFORMATIONS ABOUT SERVICE MANUALS!!! | starpho | Old Ericsson Phones & Sony Phones | 4 | 03-19-2001 08:01 |
