12-29-2001, 07:44 | #3 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Mumbai [India]
Member: 3503 Status: Offline Thanks Meter: 2 | hi<br />what happens to your 3330<br />1 if its insert simcard and then contect service you can repair by simple dejan flasher<br />use any logger chack the mcu ppm version<br />flash with good mcu from 20000 to 490000 Never flash eeprom part<br />2 [i]if from start it is contect service chack with wintesla chack for parallal cobba must be parrellal cobba failed if so your cobba must be loose contect or some one has over heated the cobba it is a hardware fault you need BGA machine.<br />[ii] if cobba is ok chack that some one before you tried to fullflash i.e from 20000 to 60000<br />then phone is F u c k e d there is no free way to repair it. your imei is changed.<br />[iii] if cobba is ok , imei ok, all lock EEEFFFF<br />try with bfrak logger 1.6<br />i tested two days before it really works<br />all locks where open ,network for some time,but then displays insert corrct card after restarting works agin for few minutes<br />thanks to Daniel Da Volli<br />his new logger works great <br />[iv]to remove conect service you need not should have dejan 1.04 box it can be repaired by dejan flasher 1.0b also.<br />regards <FONT COLOR="#ffff00" SIZE="1">[ 29 December 2001 07:53: Message edited by: gsnbhagawan ]</font> |
3330 Contact Service ...pls helpppp | PTR999 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-19-2001 19:30 |
3330-Contact Service | Ash121 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 08-29-2001 21:17 |
TRYING TO Repair 3330 Contact Service using NFREE... | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-09-2001 10:02 |
3330 contact service | qtboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-14-2001 03:04 |
3330 contact service | sdimitri | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-28-2001 16:03 |
