06-02-2003, 19:32 | #1 (permalink) |
Junior Member Join Date: Apr 2003
Member: 27240 Status: Offline Thanks Meter: 0 | How to repair a 3310/3330 unlocked by partial flash I tryied to unlock a 3330 4.50 by partial flashing, and the phone died ... He doesn't tap the network and turns off after 2 minutes. I think that MSID is invalid (a program sayed it to me ;-) ) So if you can give me the way to repair it it would be great for me. Thank you! Totoman |
06-02-2003, 23:17 | #5 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Philippines
Member: 2034 Status: Offline Thanks Meter: 24 | @thetotoman Just use Light Flashing device for DCT3 phones... an Mbus cable connected to your com port. You can also use Wintesla Files wih Nokia DCT3 Flasher by Rolis. |
06-05-2003, 11:32 | #8 (permalink) |
Member: 27240 Status: Offline Thanks Meter: 0 | Thank you men, I tested it by flashing the phone with rolis and undating FAID with original IMEI. But when I unpdate, DCT3 Flasher says it to me: XPmobile(SG) Nokia DCT3 Full Service 2002 Thanks goes out for the following: Dejan, Rolis, Sorins, G-Man, Maroon, SPEED, J, Bph&Co, and of course special thanks to Cyber, SPunlock, Lead, Victor, Marcus, Meshoz, Guar, hanoon, Hacker1, DavidB , gsm-tech, Schwantz, and Mudboys ... misc_calibrate_delay : 4600.62 BogoMIPS MBUS_OpenCOMPort : opening COM1 with delay 100 Emulation cannot be used together with MBUS commands - disabling it FLS1_GetFlashParameters : parameters found NHM-6(3330) - DCT3BT2.TIA MBUS_cmd : size of command is 12 MBUS_cmd : size of command is 12 MBUS_cmd : size of command is 12 FLS1_GetNMP : found model NHM-6(3330) FLS1_GetPhoneInfo : MCU version is analyzed MBUS_cmd : size of command is 12 MBUS_cmd : size of command is 13 MBUS_CloseCOMPort : Closing COM port And that's all! He dousn't close the COM port! Why? I don't understand. I use MBUS cable (doesn't works with FBUS). Thanks |
06-05-2003, 22:14 | #9 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Czech Republic
Member: 4246 Status: Offline Thanks Meter: 9 | If you want to write new MCU and PPM to the phone you have to use flash cable via LPT port. If phone went dead after flashing simly do as i said... After phone work you have to use MBUS cable and some new Nokiatools (Rolis etc) and clean SP locks regards |
06-06-2003, 17:51 | #10 (permalink) |
Member: 27240 Status: Offline Thanks Meter: 0 | nothing works i'm baaaaaaaaad! I tested all! I don't understand what is passing. If you have a solution who always works, give me it! I will buy a box... It's the best, but I don't know where I can have good prices; if you have too ;-) thx |
06-06-2003, 20:07 | #12 (permalink) |
Member: 27240 Status: Offline Thanks Meter: 0 | Thank you, I tried with eeprom tools, and now the phone as a valid MSID and locks 1 and 4 are closed, as I wanted... I'm happy. |BUT| (always a but!) it still doesn't tap the network and reset by itself! Then I don't understand, what? what does it want? What's the f***? Help me!! thx for your help since the begining |
@@@...How To Repair A Dead China Phone by mobi_soft...@@@ | mobi_soft | Chinese Models & Cloned Phones | 7 | 07-21-2014 08:51 |
HOW TO REPAIR GDFS cid 52 cid53 by ub | khalid0909 | Universalbox | 5 | 12-03-2008 12:33 |
How to repair killed phones while unlocking by TP ? | snsoftkiller | Nokia Hardware & Hardware Repair | 4 | 12-15-2007 01:39 |
How to repair a MOTOROLA phone step by step | hooi76 | Motorola P2k | 6 | 06-13-2007 03:27 |
How To Repair A Dead Siemens Phone By Using Dreambox?? | Eagle7 | DreamBox | 1 | 07-21-2006 15:58 |
