Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 10-10-2000, 17:40   #1 (permalink)
Member: 2297
Exclamation How to unlock all 4 locks on 3210 ver 5.36
Hi!
While I was unlocking my nokia 3210 I totaly burned eeprom. I took eeprom from another nokia (same ver.) and changed IMEI. Phone turns on normaly, but all locks are locked (FFFFFF, EEEE...). Does anybody know how to unlock this phone???
Bye.
Old 10-10-2000, 19:30   #2 (permalink)
Member: 2244
Angry
hello
i also have the same problem with my phone
and i also burned the contents of a good phone in the defected phone and this was a phone without locks
i think the info for the locks is not located in the eeprom
i have also switched the eeproms and this makes no differens about the locks
if you have some info please mail me
if i have a solution you hear from me
thanks / greetings andre
Old 10-10-2000, 20:57   #3 (permalink)
Member: 1623
Post
hi,
You can not open 4 locks with EEEE,FFFFFFEE etc.
Because security bytes in the EEPROM has been corrupted.You can not open locks with same version EEPROM and changing IMEI.
You must flash the phone.
Best regards...
Old 10-10-2000, 22:36   #4 (permalink)
Member: 2197
Question
Hi,
how can the phone be flashed ????
is it only possible with a TDF-4 box ?
please tell me more !
John
Old 10-14-2000, 04:59   #5 (permalink)
Member: 2316
Post
Well i have the same problem but the message i get is "SIM NOT ACCEPTED" when you get a solution to this problem could you please E-Mail me at [email protected]
That will be very much appreciated!!!
Thank allot.!!
And how do you Flash a EEPROM what program to i need and where can i get it from if i find anynew info i will post it here ok.
Thanks!!
Old 10-17-2000, 22:03   #6 (permalink)
Member: 2197
Post
Does anybody know how to flash a
3210 without a TDF-4 box ?
your help is very much appreciated
Old 10-17-2000, 22:15   #7 (permalink)
Member: 1623
Post
hi to all,
You can not FLASH the EEPROM!!!!
you can only upload or download eeprom.
You don't need erasing all EEPROM area before uploading.
But you must erase FLASH IC before uploading firmware.However i saw a program which is promting whether or not erasing...
You can not change any byte in the FLASH IC.
But you can change any byte in the EEPROM.
Maybe this info helps you...
Best Regards...
Old 10-22-2000, 00:33   #8 (permalink)
Member: 1723
Post
i have unlocked a fone that had 4 locks before. BUt the phone had been locked accdently to all locks. In your case the eeprom has been swapped not sure what diffrence that will make.
Ok i unlocked all the locks like this. open the phone and short pins 5+6 the other side of these pins need to be earthed, therfore touch ground with your body, as this will act as a resistor. Press unlock about 6 times and on te last unlock seperate the short. this will open lock 3, then do same for lock 2 and 4 and last lock 1.
If pins 5+6 don't work alternate and try 6+7 pins.
Trust me this works, if u are in england and want a hand doing it maybe i can HELP.
Kind regrads,
[email protected]
Old 10-22-2000, 01:19   #9 (permalink)
Member: 2084
Post
is this with locks EEEEEEE AND FFFFFFF AND CONTACT SERVICE
Old 10-24-2000, 00:07   #10 (permalink)
Member: 2316
Post
Hi to all,
I have figure out how to unlock the phone, you need to do the pin 5 trick E-Mail me for more info at [email protected]
Old 10-25-2000, 14:29   #11 (permalink)
Member: 2084
Post
how do you do that can u help me
Originally posted by Abdul:
Hi to all,
Old 10-27-2000, 16:20   #12 (permalink)
Member: 2316
Post
Hi brittnee,
E-Mail me and ill give you all the details it's too long to fit here!!
I'm sorry for the inconvionce.
how to unlock t39m, 4 locks closed (help) ezio Old Ericsson Phones & Sony Phones 3 09-05-2003 17:04
3210 , ver 5.36 Trick pin 5 0.0 % working AMTX99 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 10-15-2000 21:57
Is there are any EEPROM solution for 3210 ver. 5.36 talenat Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-19-2000 01:46
All 4 locks on 3210!!!!!!!!!! m.a.d Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-01-2000 17:54
Nokia 3210 ver 5.36 25.07.2000 , unlock ? nightxyz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 08-14-2000 01:09
Page generated in 0.32908 seconds with 8 queries
