07-21-2000, 00:30 | #2 (permalink) |
Freak Poster Join Date: May 2000 Location: Slovakia
Member: 1341 Status: Offline Thanks Meter: 0 | Ii's simply. Just take off back cover and batery. Then from inside take out antene (white thing) and iron thing. There you found 24c128(it's eeprom-8 lengs), Now read phone(example with Nokia Tool), and you must conect pin 6 and pin 7 of this eeprom. 5 times press closed( to open),but it still appears like closed. Now disconnect 6 and 7 and press closed. Now it changed to open. I try it with ver 5.31 and with 1&2 simlocks. Mark |
07-25-2000, 21:44 | #5 (permalink) |
No Life Poster Join Date: Jun 2000 Location: Bratislava.SR
Member: 1630 Status: Offline Thanks Meter: 1 | so i read phone and then i have to connect 6 and 7 with phone still running????? or can i disconnect, turn off, connect 6&7, connect back, turn on, push 5 times, turn off, disconnect, turn on, push 1x -> unlocked? thanx |
07-26-2000, 18:02 | #8 (permalink) |
Insane Poster Join Date: Jul 2000 Location: Osijek, Croatia
Member: 1711 Status: Offline Thanks Meter: 0 | Hi! I have noticed that there is on some phones side effect of conecting 6&7 weaker signal. There is more efitient way for N5110 v5.28 and N3210 v5.31! 1.You have to open the phone (without back cover) 2.Disconnect pin 8 (VCC) on the eeprom and make a switch at the endo of the two wires, outside of the phone so you can connect or disconnect the eeprom 3. Put phone back togeather and switch is outside of the phone 4.Turn the phone on 5.Conect m-bus cable to phone 6.Run nokia tool v034 and read the phone 7.Push OPEN ALL with switch ON 8.Push OPEN ALL with switch OFF 7.Push OPEN ALL with switch ON Now you see that the phone is unlocked. Just connect back the eeprom... Good luck! |
How to unlock my x-5? | Polyphonic | Phone Unlocking Codes & Maps | 17 | 11-29-2003 02:34 |
How to unlock Sagem X-5 ver: JE3,9L | PSG | ARM9 BASED M62 / M62+ | 5 | 07-24-2003 13:57 |
How to unlock 6110 v.5.48???? | GSMtricks2002 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 15 | 09-20-2002 04:47 |
How to unlock 5190 v.5.81 | jenik | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-29-2002 02:49 |
how to unlock 3210 SW 5.31 | Bob Peters | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-14-2000 21:19 |
