I can't flash read/write 8210, erase flash error??? I can read/write nothing, the cable it's 100% tested. Nokia Flasher v1.00b by Dejan: Loading Boot Loader... Boot Loader is Ready. Flash ID:20650F59 <--- ???????????????? Loading Flash Loader... Flash Loader is Ready. Erasing Flash... Erase Flash Error! Addr:00000000 In:FF Flash:00 Nokia DCT3 flasher by Rolis v5.14: ------------------* Nokia Mobile Info *--------------------------- 0000|A1 20 65 0F 59 05 FD 80 12 E0 D6 20 00 24 33 FF |Ё e.Y.§рж .$3џ 0010|FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 48 |џџџџџџџџџџџџџџџH 0020|2F 8A 24 56 20 20 35 2E 32 36 0A 31 39 2D 31 30 |/$V 5.26.19-10 0030|2D 30 30 0A 4E 53 4D 2D 33 0A 28 63 29 20 4E 4D |-00.NSM-3.(c) NM 0040|50 2E 00 20 65 0F 59 00 00 00 00 6F 00 00 00 00 |P.. e.Y....o.... ----------------------------------------------------------------------- SoftWare & HW : V 5.26.19-10-00.NSM-3.(c) NMP. FLASH TYPE UNKNOWN ----------------------------------------------------------------------- also: Nokia Unlocker v7.3 K-rad Nokia Flasher Engine Build 18, Frontends Build 14 [Nokia Tool by Rolis v1.5b] [Eeprom repair for Nokia DCT3 by Dejan] [Eeprom Tools by B-phreaks v3.0] With MBUS i can read info, recalculate faid... but the phone don't work. Anybody can help me??:confused: |
i think it was file loader problem, try to change your loader, or you can try rolis 4.77 to read and write |
Hi! If it's not Flash Loader problem, then try this: - Charge your battery; Or: - If phone is dead, take battery out, start the flashing program, when it asks you to turn on the phone, put the battery back on and press NO, if needed... needless to say, you have to have the connector on the phone... :P ;) :) Cheers. |
gsmsaver@ If it's not Flash Loader problem, i've tested before.. Rolis v4.77: the same problem... unknown flash type MoOkIe@ i have a doubt, in your second solution: - If phone is dead, take battery out, start the flashing program, when it asks you to turn on the phone, put the battery back on and press NO, if needed... needless to say, you have to have the connector on the phone... :P press NO?, where? i try with rolis 4.77 and dejan Thanks for your reply!! ;) |
do you know that unknown flash type, it doesn"t mean that you cannot erase it, just because you already erase your firmware, so when you encounter this problem, just press ok, then it will continue erase the flash file, when it was finished, it will upload a new flash file, which means a good full flash backup. after that you phone will bring back life. |
Sorry, i meant ON... :p Press power ON... Also, do you have dejan box? if so use dejan 1.05... If you don't have dejan box, then try Knok. Sorry. Cheers. |
Hi gsmsaver @, what soft do you refer?, with rolan, donДt continue when i press ok. [MoOkIe] @ I sopose it.. :) , but it doesn't work Thaks a lot, for your reply! ;) Regards. |
your flashrom may be defective. try to rework your flash |
resolder flash chip.....i had this problem too in 3210 and 3310......resoldering with hot air station work 100% by me....... |
