08-14-2002, 03:42 | #1 (permalink) |
Junior Member Join Date: Jul 2002 Age: 52
Member: 13520 Status: Offline Thanks Meter: 0 | Flashing Error Flash Erasing Error (Probably Flash loader Is not Correct) With Knok95 FLS1_Erase : erased block (65536 bytes) starting from 003C0000 FLE5_ExecuteCommand : commandblock accepted FLE5_ExecuteCommand : execution command sent FLE5_ExecuteCommand : command executed FLE5_DirectWriteByteBlockAndTrigger : delaying for 100000 microsec FLE5_ExecuteCommand : commandblock accepted FLE5_ExecuteCommand : execution command sent FLE5_ExecuteCommand : command executed FLE5_AfterReadWriteTrigger : delaying for 298 microsec FLS1_GeneralProgrammingStatus : error at 003D0000 FLS1_WriteLarge : cannot erase When this works and powers on it gives contact service Any suggestions Last edited by snoopsterg; 08-14-2002 at 04:25. |
08-15-2002, 01:13 | #2 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Romania Age: 41
Member: 11445 Status: Offline Thanks Meter: 0 | Maybe hardware failure In this case I think is the memory faulty, but you can try eeprom tools (you can find on my group) to see the Contact Service cause. Also you can check the connectors, clean them and ofcourse the battery must be fully charged. Good luck! |
08-15-2002, 09:32 | #5 (permalink) |
Member: 11445 Status: Offline Thanks Meter: 0 | Why??????????????? Because when you try to flash phone, the phone consumes power (from the battery). If the battery is not charged, in the flash process, you may recive error messages because the phone has not enough power and after that phone dead..... The flash was not fully writed on phone..... |
My-411x wont flash error Flash error (#9.1) | Mr.3. | SAGEM JTAG UNLOCKER | 3 | 01-15-2010 05:36 |
Flash colour/cid mismatch ,script error : Flash error (10.43.77) | mccm | Cruiser Suite | 18 | 05-22-2007 05:47 |
s700-script error flash error | green9 | Cruiser Suite | 1 | 09-12-2005 21:52 |
