02-22-2002, 16:04 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Denmark Age: 45
Member: 4205 Status: Offline Thanks Meter: 9 | Knok - problems When trying to use any of the commands which uses the MBUS-cable I get the following errors. I'm using Windows XP, and have no problems flashing. Any ideas? [quote]kNok - Engine build 17, Frontend build 13<br />Thanks goes out for the following:<br />Dejan, Kodo, Viper, Jozso (for hardware and cable support<br />and of course beta testing), Bph&Co, IceDragon, Steina,<br />Epilog, Invisible, Jethro, H-tom, AlAraf, Lead<br />and all the others who supports knok...<br />misc_calibrate_delay : 2949.12 BogoMIPS<br />misc_setredirection : redirection is 0<br />MBUS_OpenCOMPort : opening COM1 with delay 100<br />FLS1_GetFlashParameters : parameters found NSE-8(3210) - DCT3BT2.TIA<br />MBUS_cmd : size of command is 12<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_cmd : timed out after 10 tries<br />MBUS_SecurityCommand : cannot execute 'Enable extended commands'<br />MBUS_SetServiceMode : cannot enable extended commands<br />MBUS_GetVersion : cannot set service mode<br />FLS1_GetPhoneInfo : cannot get MCU version<br />CMD_handlecommands : cannot analyze phone<br />MBUS_cmd : size of command is 12<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_sendcommand : cannot write to COM port<br />MBUS_cmd : timed out after 10 tries<br />MBUS_SecurityCommand : cannot execute 'Enable extended commands'<br />MBUS_SetServiceMode : cannot enable extended commands<br />MBUS_CloseCOMPort : Closing COM port<hr></blockquote> |
03-06-2002, 07:37 | #4 (permalink) |
Member: 4205 Status: Offline Thanks Meter: 9 | Ehh, knok works just fine under Windows XP - what do you mean you don't believe it? I'm having problems when using the functions that DOESN'T use the flasher-cable, but uses MBUS. |
03-06-2002, 07:51 | #5 (permalink) |
No Life Poster Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks Meter: 1,592 | Hi laxxe, Window XP don't works on the Flasher. this is due to the transmittion rate which is totally different from Window 95/98/ME. Its works fine for the serial port. So that is what the cause of it. Regards Alan |
03-06-2002, 08:29 | #7 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Leiria, PT & *******, CN
Member: 3756 Status: Offline Thanks Meter: 5 | Hi! It's probably because The OS is blocking the COM... Or maybe it's because XP uses some different code for openening COM, sending commands, etc... I'm only guessing here... Cheers. |
03-06-2002, 08:33 | #8 (permalink) |
Member: 4205 Status: Offline Thanks Meter: 9 | I thought Knok was called "XP compatible"? Can any of you guys get the MBUS to work under XP (in Knok). I can use EEPROM Tools from B-Phreaks without any problems... (Well, I have to push the button twice, but I'm not the only one with this bug...) |
03-07-2002, 03:46 | #10 (permalink) |
No Life Poster Join Date: Dec 2001 Location: [winscard.SCardTransmit]
Member: 8023 Status: Offline Thanks Meter: 13 | hey, I just can't see what are you using kNok for. Well, Nutzo, please explain what your program is good for. I can not catch the point. Maybe porting it to linux - user-friendliness just like mygnokii ) Otherwise laxxe, get a reliable bootdisk with a format.com and in harder cases an fdisk.exe on board, that will solve all of your problems. (well, you may be angry now, but after several months of problems, you will agree with me ) Best Regards |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
s3650 problem [FIXED in SPT 8.7.8] | SonyBB5 | SPT BOX | 3 | 03-29-2010 22:32 |
smti update problem | ashaka | SMTi | 1 | 03-29-2010 13:23 |
Knok Problem | almoudamer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-25-2003 19:19 |
problem with Knok | 3axap | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 01-31-2002 11:46 |
