10-01-2001, 09:11 | #1 (permalink) |
Junior Member Join Date: Sep 2001 Location: Switzerland
Member: 6570 Status: Offline Thanks Meter: 0 | low battery and flash problems? I just got a flash cable to unlock my Nokia 3210 (5.36) and I'd be grateful for some help... I used a program called Jethro first, everything was apparently ok, detected a 16Mb Atmel chip and flashed it, but when it said it was finished the phone wouldn't turn on. I read some guides and got to work with Dejan flasher. Basically: -I can't read properly - I've tried with all the f_loader.bin files I have, including the one for Atmel 16Mb, and all I ever get is 00 FF 00 FF... -I've tried to write a 5.36 partial flash. Only the Atmel 16Mb f_loader.bin gets me past the 'erasing flash' stage, it says 'Done'. When it starts to write, though, I get "Flash Status error". Thanks if you're still with me. What does this flash status error mean? One thing I suspect is a low battery - it was almost empty when I started (giving 'low battery' warning). And in its current state will the battery charge as normal if I plug in the charger? At the moment the phone still responds to Dejan, but with the charger plugged in it doesn't, and this was making me slightly nervous... Thanks a lot |
10-01-2001, 12:59 | #2 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Hungary Age: 49
Member: 6472 Status: Offline Thanks Meter: 1 | Use another phone's battery which is full of charge. After this use dejan's prog with approriet atmel's f_loader.bin and an approriate (you have to try it) boot. bin (thetre are 4 type or more??)! Good luck! |
Sigmatel s70 low battery shut down problem | rockindheeraj | Chinese Models & Cloned Phones | 0 | 03-03-2010 18:55 |
6234 after one call low battery and damage and expand the battery cell pplz help | asif_ae | Nokia Hardware & Hardware Repair | 2 | 05-12-2009 06:01 |
n73 low battery and no speaker phone?? | nofear197979 | Nokia Hardware & Hardware Repair | 3 | 03-27-2008 09:16 |
nokia 6070 low network and camera problem | barthosyn | Nokia Hardware & Hardware Repair | 2 | 12-06-2007 02:49 |
Siemens C35i - Battery and Charging Problem | ams2000 | x1x to x45/x50 | 4 | 01-04-2005 00:12 |
