MAD or FLASH ? When we flashing the phone, where the mcu and ppm is stored? in the MAD or in the Flash IC? Thanks |
flash ic, of course |
flash for sure hello m8 Lead is right flash of cource . kind regards . |
do you ever try to change the flash ic? I try one in my 3310 with the new flash i brought from a friend at nokia service center, and now i can not flash it cause the flash id is unknown, it said 0200xx (i forget, cause it in my home) then i try use old flasher like darkflasher v2.13 and winflasher 1.8 it said cmd error ... :mad: the reason i change it because it contact service what should i do? BR W:confused: |
resolder or change again |
hello m8 as lead said its correct , i have changed flashes several times . kind regards . |
Correct me if i'm wrong but since we have "EEPROM Tools v3.0" now - can't you just resolder the CS one, flash it with an mcu/ppm flash, and a virgin eeprom then just calc all values? I've done this on "wiped" flashes before and have had no problem! B..r. |
@daiveb what about if physical flash is destroyed ? regrads . |
Ah - of course physical problems can't be solved with software - this is when replacements are requried!!! :) |
