Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 03-14-2002, 10:45   #1 (permalink)
Member: 662
MAD or FLASH ?
When we flashing the phone, where the mcu and ppm is stored?
in the MAD or in the Flash IC?
Thanks
Old 03-14-2002, 10:56   #2 (permalink)
Lead's Avatar
Member: 1841
Thanks Meter: 468
flash ic, of course
Old 03-14-2002, 14:23   #3 (permalink)
Member: 7327
Thanks Meter: 12
flash for sure
hello m8
Lead is right flash of cource .
kind regards .
Old 03-14-2002, 14:31   #4 (permalink)
Member: 662
do you ever try to change the flash ic?
I try one in my 3310 with the new flash i brought from a friend at nokia service center,
and now i can not flash it cause the flash id is unknown, it said 0200xx (i forget, cause it in my home)
then i try use old flasher like darkflasher v2.13 and winflasher 1.8 it said cmd error ...
the reason i change it because it contact service
what should i do?
W
Old 03-14-2002, 15:40   #5 (permalink)
Lead's Avatar
Member: 1841
Thanks Meter: 468
resolder or change again
Old 03-14-2002, 16:39   #6 (permalink)
Member: 7327
Thanks Meter: 12
hello m8
as lead said its correct , i have changed flashes several times .
kind regards .
Old 03-15-2002, 04:44   #7 (permalink)
Member: 4690
Correct me if i'm wrong but since we have "EEPROM Tools v3.0" now - can't you just resolder the CS one, flash it with an mcu/ppm flash, and a virgin eeprom then just calc all values?
I've done this on "wiped" flashes before and have had no problem!
B..r.
Old 03-15-2002, 05:26   #8 (permalink)
Member: 7327
Thanks Meter: 12
@daiveb
what about if physical flash is destroyed ?
regrads .
Old 03-15-2002, 06:08   #9 (permalink)
Member: 4690
Ah - of course physical problems can't be solved with software - this is when replacements are requried!!!
Debrand or Upgrade or Flash K608i Mshake TOTAL MultiServer 49 05-05-2007 16:51
for change language or flashing in alcatel c55x & elle need logs or not OTMAN-GSM Alcatel O.T.U.F 4 01-17-2007 15:55
Change MAD and Flash IC!!!! Mehvishal Nokia Hardware & Hardware Repair 10 03-21-2005 20:31
Flex or flash for Motorola V220 or V180 bzyk123456 Motorola P2k 0 10-30-2004 12:17
Page generated in 0.30509 seconds with 8 queries
