11-17-2001, 19:01 | #1 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | Updating MCU & PPM without logging!!! |
11-17-2001, 19:10 | #2 (permalink) |
Freak Poster Join Date: Jul 2001 Location: internet
Member: 5234 Status: Offline Thanks Meter: 0 | don't have to download, read his "solution". This solution doesn't work in 51xx&3210&61xx You must have : 1-Nokia flasher v1.0 by Dejan Kaljevic + tia files + f_loaders + ucables.com shell (download:gsmgods.net/free-nokia-e.htm)<br />2-Nokia flasher cable<br />3-NFREE 1.2 (download:nfree.gsmsearch.com) Note : Nfree v1.2 is the best free calculator for flash files and other beta versions such as nfree 1.3b3 Alabaster not good)<br />4-Full MCU & PPM flash file for your phone<br />Note : This solution work only on new nokia phones ( 33xx,62xx,82xx,71xx,83xx,88xx)<br />Note : This solution tested on 8210 <br />Now you can start... 1-Read full backup (MCU+PPM+E2PROM) of your phone and save it to backup.out 2-Write new MCU & PPM to your phone ( you should not overwrite EEPROM ) 3-Read phone full flash (MCU+PPM+E2PROM) and save it to full.out 4-Start NFREE 1.2 and open full.out 5-Go to "Changes" menu and click on "Correct Eeprom CRCs" 6-Go to "Changes" menu and click on "Correct MCU-Checksum" 7-Go to "Changes" menu and click on "Correct all PPM Checksums" 8-Save fixed file to fixed.fls 9-Write fixed.fls to phone 10-Reset phone to factory setting 11-Now your phone is working correctly by new mcu version... |
11-17-2001, 21:21 | #3 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | what does it mean? Does this solution means :<br />Changing Language or Up/Downgrading MCU?!!! <img src="rolleyes.gif" border="0"> <img src="rolleyes.gif" border="0"> <img src="rolleyes.gif" border="0"> <img src="rolleyes.gif" border="0"> <img src="cool.gif" border="0"> |
11-18-2001, 02:33 | #7 (permalink) |
Freak Poster Join Date: May 2001 Location: o(''.'')o
Member: 4647 Status: Offline Thanks Meter: 3 | it this for real guys????????? i think putting the wrong mcu to the phone could make it dead and not even viper tool 1.2 could repair this........ anybody has the guts to test this? <img src="smile.gif" border="0"> |
11-18-2001, 05:58 | #10 (permalink) |
Member: 4647 Status: Offline Thanks Meter: 3 | hahaha it doesnt work i tested it with my nokia 3310 good for me i backup the phone from 002-004 or else i would have a dead 3310 <img src="smile.gif" border="0"> would anybody want to test it on another unit maybe you will have better luck than me heheheheh |
11-18-2001, 11:14 | #11 (permalink) |
No Life Poster Join Date: Nov 2000 Age: 47
Member: 2553 Status: Offline Thanks Meter: 3 | hi,<br />i tried this method with 3310 ver 4.06<br />i flashed the phone with new ppm from 330000, i used ppm cutter from ******** before flshing, i got CS on the phone then i used Nfree ver. 13A2 and the phone was dead couldn't turn it on anymore to set it to factory settings, i don't think that this is going to work, or maybe i do something wrong!<br />Regards<br />Meam |
11-18-2001, 12:40 | #12 (permalink) |
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | Some advice for using this solution: -You must use NFREE v1.2 because it isn't beta version!!!<br />-At level(2) you must flash phone with MCU or PPM or MCU+PPM only (not EEPROM!)<br />-At level(3) you must read MCU+PPM+EEPROM for example in nokia 8210 :<br />Level1)backup:00200000-00400000<br />Level2)write :00200000-003D0000<br />Level3)read :00200000-00400000<br />Level9)write :00200000-00400000 |
11-18-2001, 12:49 | #13 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Viet Nam Age: 48
Member: 5487 Status: Offline Thanks Meter: 5 | Hi all<br />- It methode can not work for Upgrade/Downgrade or change language. It's only repaire your fone if it's not power on or wrong MCU.<br /> + If your MCU different version with MCU in your fone (language and version ) so it's can't work or it's work but no network and reset after 20 second.<br /> + If the same version (MCU) and language (PPM) and EEPROM the same address (3D0000 or 3e0000) it will work correct.<br />- I have try on alots of Unit by this method. Best regards. |
11-18-2001, 15:02 | #14 (permalink) |
Freak Poster Join Date: Dec 1999 Location: Earth
Member: 751 Status: Offline Thanks Meter: 19 | Chamkute, Are you sure that your solution worked?!!! Yes, you can "CHANGE" mcu version and ppm package this way..But your phone will end up "resetting". On the other hand, a tested cheapest way to change mcu and ppm is by using Dejan 1.0b and B-phreaks logger!!! Regards, neb |
9110 & 9210 Mcu & PPM files | raga0001 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-29-2002 01:07 |
MCU & PPM Updater Beta Version!!! | Meam | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 01-21-2002 19:40 |
HELP!!!!!Need 7110 MCU & PPM with ppm version ( J ) or ( K )...... | Sandman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-13-2002 15:56 |
MCU & PPM flasher 1.4 works without box | carlito | Nokia Multimedia | 19 | 07-27-2001 18:21 |
MCU & PPM Flasher | Cyberdog | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-20-2001 19:59 |
