moderator helps need ,3310 ,1st Boot Err: Bad Resp DCT3 hello moderators , i have 4 nokia 3310 mobile which shows following error:- 1st Boot Err: Bad Resp DCT3 1st Boot Err: Bad Resp UPP, 02 FF FF 72 Rebooting Mobile i already changed the power ic appproximately 15 times each...... but same problem ............if u have a nice solution then plz give me......... very important matter & solution urgent need......... plz don't ignore it.....................thx in advance................................ |
Flash it with dejian flasher. |
change flash IC Tihs is meaning of error maseges. 1st Boot Err: Bad Resp DCT3 1st Boot Err: Bad Resp UPP, XX FF FF 72 XX = 01 - mobile not power up XX = 02 - mobile not enter the flash mode XX = 03 - UPP not respond |
change ic flash first and then flsh ur mobile |
Maybe you should change cable. I had same problems with 5210, 6210 and when I changed cables it was ok. |
Yes, check the cable connection, f-bus pads, if OK change Flash IC. rgds, |
griffin ill also help u drict flash it with nice cable it ill help u wink shafeeq geo mobiles |
change the flash ic and the ram |
maybe ur cable have problem as u said u hav 4 units with same problem!!! try flashing it in dct3 flasher... |
try to change cable sir.. is it still dont work change flash ic Br |
is it done br?pls tell the situation |
I need pmm files of 3310,2100, anybody help me plz. |
http://forum.gsmhosting.com/vbb/show...&postcount=331 Regard's Munna Bhai |
1 Attachment(s) 3310 @ 21ere00 pmm files here |
check your usb cable ,or your data cable , possibly cable problem try dct3 flashers like rollis or knok bfore doing anything..... |
