My Nokia 3310 have no signal!!! I bought Nokia 3310 which was bad flashed (with eeprom). Now it have no network. I tried to flash it with full flash (with eeprom) and then I use Eeprom tools 3.0 to change IMEI, calculate and update FAID and unlock SP. But it still have no network. After turning on there is network for 10 seconds and after this time there isn't network. Can it be an original IMEI which I don't change? How I can change my Original IMEI? I have a Dejan flasher cable and dual (MBUS & FBUS). Do you know what can it be? I have two Nokias 3310 and both have the same problem. |
Are you sure your FAID update and SP lock and Factory reset were successful with your dual M/FBUS cable? That might be the culprit! Try doing it with NK_CALC!! If it dont get signal, better think of a "harder" problem like HARDware :D Yup, if all software solution don't work, you're left with the option to bring it back to your nearest NOKIA service Center. :D |
It can't be hardware problem, becouse the man who sold me the phone unlocked badly the phone and flashed eeprom. But before this the phone worked correctly. I'm sure you sure that FAID update and SP lock and Factory reset were successful with dual M/FBUS cable. I know that many people have the same problem as me, but they also don't know what to do. Now I can't use nk_calc because I havent MBUS cable, I have only Dual. Are there some differences between effects of NK_CALC and EEPROM TOOLS? |
Hi, Try to use knok, flash the phone with full flash mcu+ppm+eeprom put original imei & imei back to original as in phone´s label. Then calc Sp with knok. Good Luck |
thanks in advance.:cool: |
try this site http://www.schwantz.hpg.ig.com.br/mypage.htm |
