New Notebook + Dejan=Doesn't work/WinFlasher work fine.. Hello, <br />I have bought a notebook, IBM a22e Celeron 800 with 64MB RAM and win98SE. I have tried my phone read with Dark Shell but I got this message: "Phone NOT respond Load Boot Data" and done. I have tried the read with Nokia flashDownLoader (it's a flashreader under windows) and it's work fine! Jethro also doesn't work.... I've tried reduce the speed in BIOS but with 240Mhz I got errormessage, with 450Mhz also this error. The flashreader under windos work fine with all speed.<br />Have somebody idea? What can I do? <br />Thanks for the help...<br />dsl |
Hi try select lpt port as BIDIRECTIONAL in bios options!!! OrbiTel |
It should have no effect on Dejan interface. |
hi<br />i have a laptop too compaq pentium ii 366 which dejan doesnt work on it so i simply bougt a pc to use with dejan.( i have tried everything above but no use!). regards farry |
I already solved this problem.<br />A small modification in Dejan flasher interface is necessary.<br />Check your mail, Farry! |
Hi! @Lead? Is this modificated version also for notebooks which have 166 MHz???? if yes then send me please too! thx cu <FONT COLOR="#ffff00" SIZE="1">[ 23 November 2001 14:44: Message edited by: igi1 ]</font> |
Hi Lead , camn you also mail me the modified flasher , <br />[email protected] |
hi to everybody.<br />it is said that the pararlel port voltage of Laptops aren't enought.this is for old laptops like 486,pewntium,<br />i don't know is that the same with the new one.<br />we need a external VC for dejan cable.<br />here is attached the sheme. hey i cannot find attach button. help me |
thanx lead regards farry |
thanks lead but you can give information for all |
Give it free.<br />Give it free.<br />Give it free.<br />Always, give it free.<br />Why should I?<br />Why should I?<br />Why should I?<br />This ***** me A LOT. Okay, here it goes, to make YOU HAPPY: Remove the wire from LPT pin 22 and connect it to the pin 18. Then the Dejan interface should work with most Compaq notebooks. |
hi Lead <br />please send me solution or schematic. My note book pentium-II speed 233Mhz. I'm using soft NU2000 v1.11b. not work only 3210. every time i'm using soft. show in display sending aplication error. Other phone good unlocking .<br />thank you<br />================================================= <br />regards<br /> <img src="confused.gif" border="0"> |
@siemens...<br />Try disconnecting the BTemp pin. |
Hello Lead, <br />I don't understand this problem:<br />why can't read with Dark's shell while I can read the phone with NokiaDL?? My interface is wrong? Or simple the notebook is bad?<br />thanks for your help...<br />dsl |
