Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 02-25-2002, 02:38   #1 (permalink)
Member: 7814
Post nk_calc problem.....
hi,<br />I tryed to set SP data with function F3 in nk_calc and now my 5110 is 4 lock closed with EEEEEEEE and FFFFFFF.<br />Could it be the processor (AMD duron) or the cable? Any ideas?
Thks
Old 02-25-2002, 03:08   #2 (permalink)
jan
Member: 233
Thanks Meter: 36
Post
Hi
Try to make again, then make factory rest!.
If soft don`t work with windows, start via Plain DOS and CWSDMPI driver.
Jan
Old 02-25-2002, 03:21   #3 (permalink)
Member: 8590
Post
Hello Friends. I have just tried dejans software nk_calc and i will post results;
Computer
INTEL PIII 1000MHZ<br />QDI ADVANCE 10-I Motherboard<br />512 RAM<br />M2bus cable (to serial port)
RESULT
Tried Nokia 3310 After uploading Full Flash (with normal flasher. (20000-40000)<br />action F1 and F2
When Phone ON: Responce Bad Connection !<br />When Phone OFF: Responce Bad Connection !
Could it be computer Problem? All other dejan soft work Ok.
Thanx
Old 02-25-2002, 03:28   #4 (permalink)
Crazy Poster
Member: 9711
Post
So it s not only me!!<br />I think that this proggie works only with COM2. Tough luck coz i have f#$%ed up my COM2 conflicting with an infra red device...<br />Damn!!!
Any other suggestions???
Let me get this straight...this software changes IMEI number to ALL DCT3 phones?? (5110s??)
Cheers!
Old 02-25-2002, 04:08   #5 (permalink)
Member: 9254
Thanks Meter: 4
Post
Hi
Program work for me - would not work with original nokia DAU-9P fbus/mbus cable.<br />works with home made m/bus cable (lol).
<br />hope this helps
Old 02-25-2002, 04:10   #6 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 782
well that makes the 3 of us m8.. everytime i press f1 or f2 i get a bad connection message!!!!
hmmmmmm.... im using p2 300 win98se...
what seems to be the problem could anybody help? <img src="smile.gif" border="0">
Old 02-25-2002, 04:13   #7 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 782
Post
marty
im using both!!! still no good!!! i wonder y?
any new ideas m8?
Old 02-25-2002, 04:14   #8 (permalink)
Charly's Avatar
Member: 2008
Thanks Meter: 4
Make the cable
<img src="wink.gif" border="0">
Old 02-25-2002, 04:37   #9 (permalink)
Member: 7814
Red face
@Jan:<br />I did the F3 thing again and the full factory with wintesla and all the same <img src="frown.gif" border="0"> <br />And the program dont show any errors at all:<br />
It works under Windows ME with home made MBUS interface based on MAX232 but...... now 5110 with 4 lock closed EEE FFFF
thks
Old 02-25-2002, 04:39   #10 (permalink)
Member: 9167
Post
Make the external power on Mbus cable
[ 25 February 2002: Message edited by: TechSonic ]</p>
Old 02-25-2002, 04:55   #11 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 782
Post
hi there can somebdy pls tell wat exactly to do to make this sw run? what should i do with my cable to make this functional? can i have a scheme?
thanks
Old 02-25-2002, 05:14   #12 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
Post
Having the same problems here, be it com1 or com2, Dejan's soft just reports bad connection. Any ideas?
Old 02-25-2002, 05:20   #13 (permalink)
Member: 9167
Post
[quote]Originally posted by Hanukkah:<br /><strong>Having the same problems here, be it com1 or com2, Dejan's soft just reports bad connection. Any ideas?</strong><hr></blockquote>
Try to start Windows in safe mode<br /> <img src="rolleyes.gif" border="0">
Old 02-25-2002, 06:21   #14 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
Post
I've tried to run it in safe mode.
I used install first to install imei.def and sp.def to root directory.
executed setup to setup the soft to work at com1.
Still get bad connection. Do i need to build the cable that is included?
Old 02-25-2002, 06:24   #15 (permalink)
ryumahon's Avatar
Member: 4021
Thanks Meter: 782
Post
im making my own cable now... inform you later if it works.....
hannukah can i have your mobile number?
thanks
Empty display after nk_calc laxxe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 45 03-29-2002 07:11
Please help... 6110 have 4 locks after nk_calc - unable to repair :-( uu1dx Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 03-04-2002 23:52
Big problem with nk_calc !! AlexG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-26-2002 02:18
nk_calc Progg work with C-Bus Kabel from bosch 909 Sprayer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-25-2002 20:45
pls hlp for nk_calc!!! gsm-lord Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 02-25-2002 16:14
Page generated in 0.27418 seconds with 10 queries
