nokia 1280 lcd way plez help hi dear .... i am facing problem with NOKIA - 1280. first no light in the set, i checked coil - its ok, then change LCD then no respond and also no LCD after that. please help me .... |
mosharrof 1280 no light please help me. |
1280 light solution hello bro 1280 ke light ke jumper lagao 11 no pin ko light coil ke paas bane two black dots main lft side wale par or 10 no ki pin ko rigt black dots par |
1280 lcd ways [IMG]http://1.bp.********.com/-LqLn0MYGhXo/Tg6UHnu-kVI/AAAAAAAADqc/J9Ci3omGMuo/s400/Nokia+1280+LCD+Solution+Ways.png[/IMG] BR Gsm Universal |
thanks Gsm.Universal |
china Nokia B200 3sim how to unloke hello Gpgdragon teem plez help me not unloke b200 china 3sim 1st Reset 2 unlock 3 format not have red file i m all tery but stel phone look infoooooooo Initializing... DA_LIB_VER_3.5.0.2 It is sensing the pinout fast... D-=23 D+=22 Searching commport...please wait... Connecting... Error: Your software has been restricted. Spd USB-to-Serial=COM5 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900025A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 230400 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_M36C0W6050T0 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=359624726970183 IMEI 2=359624726970209 --------NOR_FLASH_CONFIG-------- Flash Bank count=4587595 EFS sector count=0 File sector count=0 Sector size=0x00000000 Flash start addr=0x00000000 Flash size=0x00800000 Fix NV addr=0x00000000 Product information addr=0x00760000 MMI resource addr=0x0000002B ------Auto Format Address------- Start=0x00000000 Size =0x00760000 Read FS info...done :confused::confused::confused: plez help me |
try this for display light 1616 ..1280..1800 display light solution.jpeg - 25 Kb |
1280 diagram does not? |
Nokia 1280 LCD light Solution Ways.png - 173 Kb try this solution its 100% tested and working solution |
