01-28-2001, 04:29 | #1 (permalink) |
Junior Member Join Date: Jan 2001
Member: 3161 Status: Offline Thanks Meter: 11 | Full Flash 5130 V05.61 Please no partial flashes. Thanks in advance. Peter |
01-29-2001, 20:02 | #3 (permalink) | |
Member: 3161 Status: Offline Thanks Meter: 11 | Quote:
Thanks for your answer. I tried to full flash with 5130 05.00, phone shows false lock information but no cs. It's important, that you ONLY switch on phone but without sim or without entering PIN code. Then there is no CS. So since 05.00 for 5130 doesn't work for 5130 05.71, I tried 05.24 for 5110! full flash. I switched phone on, didn't enter PIN code, connect to nokia tool by pro 034, unlocked it (1 click at each closed lock), switched phone off, reflashed full with 05.71 for 5130. Switched phone on, entered PIN code, phone is open on all locks and finds network. 100% solution! Best regards, Peter. | |
The Following 2 Users Say Thank You to nokia_flash For This Useful Post: |
01-30-2001, 01:22 | #5 (permalink) | |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Yes very clever it will work only because you can unlock this phone without dejan, this will not work on later phones and differant models but all the same it does work if you think at it logically. Well done Charlie ps wish i could do the same withh 3310's Quote:
The Following User Says Thank You to Charly For This Useful Post: |
06-26-2011, 12:49 | #6 (permalink) |
Registered User Join Date: Sep 2008 Location: HardWare+Software & Unlocking
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | Version from phone: 07.97 Version from file: 07.97 MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 3] - C0853AF5 Using device: HTI BOX, FW ver: 00.17 Driver: uhci:hub:ccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Reading Important data ... Invalid imei plain, RPL backup skipped. CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 08E000144A1E8A56D5FF4B61BCF28E1F6ED59133 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 1 min 56.719 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 35.078 s Processing PPM file: rm495__07.97.ppm_mena_a1 [BB5,BB5 ALGORITHM] size: 6.07 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 37.062 s Flash programming ... Programming completed in 30.547 s Processing CNT file: rm495__07.97.image_mena_a1_red [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 43.547 s Flash programming ... Programming completed in 51.125 s Total time for flashing process(boot+erase+write) was 8 min 28.891 s Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 12345610654321-? Battery voltage: 4800 mV, current: 72 mA Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted |
06-26-2011, 12:49 | #7 (permalink) |
The Following User Says Thank You to Naeem123e For This Useful Post: |
07-03-2011, 05:55 | #8 (permalink) |
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | 5130 usb full flash :D MXKEY Serial: [FT SCR2000 0] - C08109BA Driver: NMWCD, ver: 7.1.32.62 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Processing MCU file: rm495__07.97.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: D74612 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 0AC00117160F7E560C9B3E4D4896B387915F191D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x59940 bytes Update Server code succesfully sent to phone. Device found: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 27398028 Verifying communication to device OK. Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] erased in 0.656 s CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.609 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.422 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.375 s CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 27.109 s CMT FLASH,NOR area [01380000-0151FFFF] erased in 7.719 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 7.313 s Processing PPM file: rm495__07.97.ppm_mena_a1 [BB5,BB5 ALGORITHM] size: 6.07 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 41.047 s Flash programming ... Programming completed in 27.532 s Processing CNT file: rm495__07.97.image_mena_a1_red [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 22.360 s CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 26.546 s Flash programming ... Programming completed in 39.406 s Total time for flashing process(boot+erase+write) was 8 min 55.938 s Waiting for device boot up ... Device found: nmwcdc\Nokia 5130 XPressMusic USB Phonet, PORT_ID: 375B2DD3 Verifying communication to device OK. Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35422303032732-4 Product Code: 0576625 Battery voltage: 3994 mV, current: 64 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354223030327324 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
07-03-2011, 15:38 | #9 (permalink) |
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | help me MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0853AF5 Using device: HTI BOX, FW ver: 00.17 Driver: uhci:hub:ccgp:WinUSB, ver: 3.5.0.0 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 09F00015BFA68D56490093A53BE9D1D410998659 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 Storage0: 00EC 2400 - 0000 8A31 [Samsung ] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Processing MCU file: rm495__07.95.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 1 min 13.562 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 1 min 27.078 s Processing PPM file: rm495__07.95.ppm_mena_b [BB5,BB5 ALGORITHM] size: 6.31 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 26.562 s Flash programming ... Programming completed in 32.391 s Processing CNT file: rm495__07.95.image_mena_b_blu [BB5,BB5 ALGORITHM] page size: 128 K size: 8.26 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] CMT FLASH,NOR area [02160000-03FBFFFF] erased in 56.797 s Flash programming ... Programming completed in 40.094 s Total time for flashing process(boot+erase+write) was 6 min 3.266 s Phone not responding ! |
Nokia 5130 V05.71 unlock with 5110 V05.24 !!!!! | nokia_flash | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 03-20-2010 21:45 |
5130 5.61 DSP-3 full need | roniri | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-30-2001 23:30 |
Urgenttly need full flash 5130 5.71 | rerednaw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-23-2001 16:59 |
Nokia 5130 Fill Flash V05.61 | nokia_flash | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-28-2001 04:32 |
