07-27-2005, 10:27 | #1 (permalink) |
Junior Member Join Date: Jul 2005 Age: 26
Member: 163740 Status: Offline Thanks Meter: 2 | Nokia 3210 No Network |
The Following User Says Thank You to Raimond For This Useful Post: |
07-27-2005, 11:38 | #2 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Turkey/Kastamonu Age: 52
Member: 133173 Status: Offline Thanks Meter: 119 | hi check antena connector(antena contact)and soldering...check antena swich or change...if still not result..change pa and rebuld imei full factory reset..you will try send post the result...regards |
08-02-2005, 02:40 | #7 (permalink) |
Major Poster Join Date: Jul 2005 Location: pHiLiPpInEs Age: 41
Member: 165184 Status: Offline Thanks Meter: 0 | -3310 no power try to program it first... if not responding, check voltage on switch and ground..it should be about 2.4v...then 3.6 when u try to power it on...if no voltage... check line of r224... check all positive ways.... |
08-06-2005, 16:26 | #8 (permalink) | |
Freak Poster Join Date: Apr 2003 Location: Romania Age: 47
Member: 27330 Status: Offline Thanks Meter: 1 | Quote:
08-21-2005, 16:57 | #9 (permalink) |
Insane Poster Join Date: Aug 2005 Location: philippines Age: 48
Member: 169368 Status: Offline Thanks Meter: 3 | i have the same problem with 3210, i manual search only 1 or 2 networks appear. when i select, it is not accessable, of course there is no antena cignal, aside from this the right antena has its TOP terminal cut out from the board, how can i make a jumper for this? also, i changed cobba, full flash, there was a signal, then when the lights went out, the signal was gone. What can i do next? thank u for all those that will give advice! |
08-22-2005, 10:57 | #10 (permalink) | |
08-23-2005, 03:03 | #11 (permalink) |
Member: 169368 Status: Offline Thanks Meter: 3 | yes sir i will try what u suggest and i will post results. thank u and i will wait for the pics i hope u can show me how to make jumper for antena terminal that has been cut out of board. thank u very much for ur help. |
08-24-2005, 17:07 | #14 (permalink) |
Member: 169368 Status: Offline Thanks Meter: 3 | mine isn't but thank u very much to all that helped and for the pics mr. fabian, i have kept them in my file for future refrence. Thank u very much! |
Nokia 3210 NO NETWORK | GSM Crasher | Nokia Hardware & Hardware Repair | 7 | 12-14-2007 15:31 |
Nokia 3210 No Network Covrage ??? | amey | Nokia Hardware & Hardware Repair | 0 | 02-26-2007 14:55 |
Nokia 3210 no network. | spvaka | Nokia Hardware & Hardware Repair | 1 | 07-01-2003 16:27 |
Nokia 3210 no network? | xmans | Nokia Hardware & Hardware Repair | 2 | 01-17-2002 19:24 |
3210 - no network ?! | Liquid | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-15-2000 02:30 |
