04-08-2002, 13:03 | #1 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Russia
Member: 7928 Status: Offline Thanks Meter: 0 | Nokia 3210 problems with LCD Such problem: Has restored from dead NOKIA 3210, all works - calls etc. but one problem has remained bad contact in a place of a joint LCD - RUBBER - PCB, rubber took from other device - problem has remained. Thus if to press slightly the screen that LCD is included and works. So actually question who how struggled with such problem? All good.... With the best regards, Alex Sed |
04-08-2002, 19:45 | #2 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Hungary Age: 49
Member: 6472 Status: Offline Thanks Meter: 1 | I have struggled such problem. I changed rubber, OK for 2 month, after get wrong contact again. I dissasembeld again the LCD, cleaning it, I cleaned the rubber contact with a rubber (to remove some rubber layer and pull up some new metal conntact from the rubber connector). So, most of the time work good, but somtimes I have to make pressure, and it is enough to get contact again for some days. It is a technological problem, newer phones like 3310/30 and DCT4 has no rubber connector, these are use metal spring connector. |
04-17-2002, 20:56 | #4 (permalink) |
Major Poster Join Date: Dec 2001 Location: rp
Member: 8113 Status: Offline Thanks Meter: 1 | yes i agree, although for some time contacts from the pcb may be misalligned it is still the best. For old rubber connectors, you just need to strech them a little bit. the prolonged pressure from the screen may have squeezed/compacted it a little bit, but after streching it contacts will be fine. have tested this on my phone or better yet change to a new rubber connector. |
Problem with lcd change nokia 6500s | sheibak | Nokia Hardware & Hardware Repair | 3 | 11-29-2009 16:17 |
Problem with LCD after unlocking V980M | vinny | Motorola P2K (USB-Smart) | 17 | 05-26-2006 00:36 |
9500 problem with LCD´s and signal | André_F | Nokia Hardware & Hardware Repair | 0 | 05-16-2006 22:17 |
VS2 Problem with LCD after unlocking? | byteforce | SagMaster Team OLD Products | 1 | 04-21-2006 13:18 |
BIGGG ProBlem With LCD 3310 | Mierdita | Nokia Hardware & Hardware Repair | 3 | 12-04-2004 17:17 |
