07-22-2002, 00:04 | #1 (permalink) |
Junior Member Join Date: Jul 2002 Location: Nederland Age: 36
Member: 13972 Status: Offline Thanks Meter: 0 | Nokia 3310/3330 No network signal |
07-22-2002, 01:03 | #3 (permalink) | |
Member: 13972 Status: Offline Thanks Meter: 0 | Quote:
07-23-2002, 18:15 | #5 (permalink) |
Member: 13972 Status: Offline Thanks Meter: 0 | I did some things with the datacable and nokia tool 035 and with the oter software is used above, and now i get network for a couple of seconds and then its lost network |
07-26-2002, 23:55 | #6 (permalink) |
Insane Poster Join Date: Apr 2002 Location: Denmark
Member: 10692 Status: Offline Thanks Meter: 0 | TO blaat: Have you tried to apdate FAID. Use bus and nk_calc from dejan (use F1). If the eeprom is from another phone, you get 4 locks closed, because the FAID is different from phone to phone. It depends on COBBA. hope this helps |
07-27-2002, 01:35 | #7 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | I'll assume that you have 4 locks closed, becuase of bad solderings under COBBA IC due to corrosion. You can't just reset sp locks and have signal. You have to reball or replace your COBBA IC. Apply solvent on the board and brush it to remove all other corrosion. |
Nokia 6230 No Network Signal | adeel786 | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 10-14-2005 15:11 |
Nokia 3310-3330 or 3315-3330 | EvilNaziMonkey | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 07-12-2003 14:32 |
My Nokia 3310 have no signal!!! | tomekkk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-15-2002 02:08 |
Nokia 3310/3330 Signal Problems - Help Required | max8108 | Nokia Hardware & Hardware Repair | 8 | 01-24-2002 09:56 |
Nokia 3330 V4.30 no network signal | GSM-Unlocker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-20-2002 18:46 |
