Nokia 3310 big problem!! HELP!! Hi Today i have 3310. First what i say is I dont know orginal imei from 3310. I flashed her by Universal Box 3.0 by flash from 3330 with eeprom then phone is dead. Next i flash with 3310 without eeprom and phone still dead. Next time i flash by flash from 3315 also with eeprom and phone work, but imei is 000000000000000. I Rebuild Imei with Twister but also the same. When i put SIM Card phone starts on the display i can see operator name but can't "take" network coverage and also after 10-15sec phone resets and write "SIM CARD not accepted". Any idea? I think i need flash for 3310 with eeprom!! br. fingusio |
You can`t flash 3310 with 3330 flash, doesn`t match 3330 flash is bigger and this is not the only problem. Copy a full flash from another 3310 flash it and flash it phone will work. Take care u need to do full flash, because u erased eeprom. When u flashed with 3315 flash it shows u imei 0000000000 because u have wrong data to eeprom fields. Of course after flash writting u need to do faid, IMEI repair etc.... BR, xyz |
Aaaaaaa :) that i think:) Maybe you or someone have full flash from 3310 with eeprom? best regards from Poland fingusio |
Hello i have the same problem fingusio what did you do to over come this matter. |
I wrote flash through Twister (MCU+PPM), then i wrote virgin eeprom and I changed imei and the phone revived br. fingusio |
write pm file with twister and rebiult imei |
hello help please 1100 not charging no signal and heats up. |
Change UEM and next time be sure and post to right section BR, xyz |
