02-15-2005, 20:15 | #1 (permalink) |
No Life Poster Join Date: Jan 2005
Member: 104066 Status: Offline Thanks Meter: 62 | Nokia 3310 Contact Service I have a nokia 3310 which posts Contact service its cobba is 00000000. Help me please |
The Following User Says Thank You to nzeiga For This Useful Post: |
02-26-2005, 15:36 | #2 (permalink) | |
Freak Poster Join Date: Feb 2004 Location: Bosnian Kingdom Age: 46
Member: 52096 Status: Offline Thanks Meter: 8 | Quote:
If steel in contact service, change cobba BR | |
02-27-2005, 09:10 | #3 (permalink) |
Freak Poster Join Date: Jan 2005 Location: GSM Center Ro Age: 20
Member: 104241 Status: Offline Thanks Meter: 6 | Make a test with eepromtools and see what is damage. If it said cobba - failed, you must change cobba. If all are ok, then flash mcu+ppm+eeprom, then rebuild imei, then make resets. |
05-21-2005, 20:24 | #6 (permalink) | |
Registered User Join Date: Oct 2003 Location: Vietnam Age: 47
Member: 40808 Status: Offline Thanks Meter: 10 | Quote:
regards | |
The Following User Says Thank You to taihv For This Useful Post: |
05-23-2005, 02:01 | #7 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: brunei
Member: 141262 Status: Offline Thanks Meter: 348 | eeprom tools!!! Quote:
i got an info that this eeprom tools can repair contact service!! like if the eeprom tools said mcu eeprom tune sum test failed.... just click the eeprom repair the 3310 contact servicewould be ok... thanks.. here is my email if u have soft for that... thanks again [email protected] | |
05-24-2005, 10:53 | #9 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 48
Member: 79443 Status: Offline Thanks Meter: 11 | pls i have 3310 and 6310 showing contact service but after flahing with twister it's still showing contact sirvice what do i do |
The Following User Says Thank You to abel peter For This Useful Post: |
05-26-2005, 03:35 | #11 (permalink) | |
Member: 141262 Status: Offline Thanks Meter: 348 | Q&A Quote:
put your 3310 using an mbus cable tick test!!! there u can see the prob.. like it would say mcu eeprom tune sum test failed.... cobba parallel or cobba serial.. if cobba serial - replaced cobba cobba parallel - just reheat the cobba.. mcu rom......test failed... still reprog.. use an alternative flasher soft... mcu eeprom only just tick the eeprom repair and faid that would be ok.. but if u have the guts try replaced the cobba IC of 6310 and 3310.. gud luck mate.. | |
08-11-2007, 09:11 | #12 (permalink) |
Registered User Join Date: Feb 2004 Location: Bangladesh Age: 50
Member: 52964 Status: Offline Thanks Meter: 5 | Nokia 3310 Contact Service Chack info MCU Sw : V 06.07 17-06-03 NHM-5 (c) NMP. PPM Sw : V 06.07 17-06-03 NHM-5 (c) NMP. DSP Sw : B60.6.756 03-Jan-01 NHM-5 (c) NMP. DSP ISw : ROM 6 PPM Lp : J ASIC : MAD2 G-01 COBBA : D21, S/n: 00000000 Prod.Id : 4F (79) MsId : 83C980FE406449CBB99E88CEB9 IMEI Net: 305698-25-654789-7 IMEI Osn: 305698-25-654789-7 Security: 12345 Locks : Mcc: 001-01, Msin: 0000000001 Locks : Gid1: 0000, Gid2: 0000 Locks : L1 Open L2 Open L3 Open L4 Open Locks : Fact 00 Fact 00 Fact 00 Fact 00 Change your COBBA and flash your phone (UFS-3) 1000000000000000% ok |
08-11-2007, 12:10 | #13 (permalink) |
Freak Poster Join Date: Feb 2005 Location: Ukraine, Chernivtsy region Age: 39
Member: 112820 Status: Offline Thanks Meter: 75 | 1st. - Change COBBA 2nd. - Full erase flash using UFS 3rd. - Fullflash (MCU+PPM+EEPROM) 4th. - Rebuild IMEI 5th. - All UI Settings |
08-19-2007, 09:49 | #15 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | 3310 contact servic solution hi, at the first time need to check with full falsh.then ui sating.then rebulid imi. remember must be erese falsh. if not done ?then need to hardware solution .number one change cob.if not done change falsher.that,s it.. thanks |
Nokia 3310, contact service | rutin | Nokia Hardware & Hardware Repair | 9 | 08-12-2005 20:22 |
nokia 3310 contact service | malkjos | Nokia Hardware & Hardware Repair | 11 | 08-19-2004 20:08 |
Nokia 3310 Contact service. | serg796 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-08-2003 12:52 |
Nokia 3310 Contact Service | MrHazeem | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 12-12-2002 17:25 |
Nokia 3310 Contact Service | Williamcwy | Nokia Hardware & Hardware Repair | 1 | 02-06-2002 13:51 |
