nokia 3310 contact service i have a nokia 3310 with contact service problem i flash with twister flashing is ok but phone still on contact service,plzzzz tell me which software or device i use to flash this kind of nokia 3310.... |
you need to flash mcu+ppm+eeprom, i don't think twister can do that job. use eeprom tools to diagnose the reason for contact service. |
read with "geoflash" full flash fron working phone (2MB for 3310), then flash your phone with it then do repair imei, set faid, sfr, with NokiaTools by rolis1.8 all software www.unlockeasy.com |
get info with ufs or twister if cobba sn is 00000 change cobba if imei is 656565...... change flash ic |
i have same problem with 3310. I changed to new cobba openlined w/ rolis 1.8. the unit works, then the next day client came back saying the problem is there again. This is the 2nd time i changed the cobba both bnew. Could it be the board? what other test should i do? |
change flash ic or rehot components around the cobba |
get a working 3310, read the pm and save it, then use it to flash the phone. that means u will flash with 3 files. then go to nokia tool by jordik, rewrite imei, and update faid, clear sim lock, reset software, select all, make selected. its ok :D Quote:
thanx friendz 4 all ur support.... |
friend plzzzz tell me wat iz geo flasher???? |
2 Attachment(s) @HUM flash the mobile with this flash i attach to you it's mcu + ppm + pmm(eeprom) after that make rebuild imei and write your original imei and UI settings if still the same problem so it's will be hardware problem and it will be coppa ic |
hey friend, try flashing your phone with a older version of flash file, try doing both downgrading and upgrading the flash file, if this dont work, then try changing the cobba, and before changing the cobba read your phone with the Twister, Tornado or a Power flasher box - you know what i mean yeah.. read info of your mobile and if you get the cobba 00000 in information then you only have to replace the cobba IC. for more information contact me by email or sms ::: email :: [email protected] sms :: 0094777173707 br m.intiqab |
thankyou Quote:
this are options for you in the future. thank all for this help ...................... bestman |
3310:no network Pls I need solution 4 a 3310 that cant even show signal at all except when one gets to a particular part of the town.Only that part of town. Please !! |
and then rebuild IMEI :) |
