08-23-2005, 01:11 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | nokia 3310 contact service |
The Following User Says Thank You to HUM For This Useful Post: |
08-23-2005, 01:46 | #3 (permalink) |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | read with "geoflash" full flash fron working phone (2MB for 3310), then flash your phone with it then do repair imei, set faid, sfr, with NokiaTools by rolis1.8 all software www.unlockeasy.com |
The Following User Says Thank You to BouRRi_GSM For This Useful Post: |
08-23-2005, 22:31 | #4 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 41
Member: 108629 Status: Offline Thanks Meter: 16 | get info with ufs or twister if cobba sn is 00000 change cobba if imei is 656565...... change flash ic |
The Following User Says Thank You to Ashiq Rasoul For This Useful Post: |
08-24-2005, 17:03 | #5 (permalink) |
Insane Poster Join Date: Aug 2005 Location: philippines Age: 48
Member: 169368 Status: Offline Thanks Meter: 3 | i have same problem with 3310. I changed to new cobba openlined w/ rolis 1.8. the unit works, then the next day client came back saying the problem is there again. This is the 2nd time i changed the cobba both bnew. Could it be the board? what other test should i do? |
08-25-2005, 09:42 | #7 (permalink) | |
Cheater -Don't Deal with him- Join Date: Aug 2005 Location: /%%temp%%.;adb
Member: 172434 Status: Offline Sonork: 100.161280 Thanks Meter: 577 | get a working 3310, read the pm and save it, then use it to flash the phone. that means u will flash with 3 files. then go to nokia tool by jordik, rewrite imei, and update faid, clear sim lock, reset software, select all, make selected. its ok Quote:
The Following User Says Thank You to ::gsmcoder:: For This Useful Post: |
08-28-2005, 22:21 | #10 (permalink) |
Freak Poster Join Date: May 2003 Location: Egypt - Elmahalla Elkobra Age: 41
Member: 30073 Status: Offline Thanks Meter: 18 | @HUM flash the mobile with this flash i attach to you it's mcu + ppm + pmm(eeprom) after that make rebuild imei and write your original imei and UI settings if still the same problem so it's will be hardware problem and it will be coppa ic |
The Following 5 Users Say Thank You to teefa For This Useful Post: |
09-04-2005, 10:04 | #11 (permalink) |
Junior Member Join Date: Aug 2004 Location: Sri Lanka
Member: 76067 Status: Offline Thanks Meter: 1 | hey friend, try flashing your phone with a older version of flash file, try doing both downgrading and upgrading the flash file, if this dont work, then try changing the cobba, and before changing the cobba read your phone with the Twister, Tornado or a Power flasher box - you know what i mean yeah.. read info of your mobile and if you get the cobba 00000 in information then you only have to replace the cobba IC. for more information contact me by email or sms ::: email :: [email protected] sms :: 0094777173707 br m.intiqab |
09-09-2005, 15:37 | #12 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: MUMBAI (MAH) Age: 52
Member: 153804 Status: Offline Thanks Meter: 0 | thankyou Quote:
09-22-2005, 18:32 | #14 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Africa
Member: 180758 Status: Offline Thanks Meter: 13 | 3310:no network Pls I need solution 4 a 3310 that cant even show signal at all except when one gets to a particular part of the town.Only that part of town. Please !! |
09-22-2005, 18:50 | #15 (permalink) | |
Freak Poster Join Date: Aug 2005 Age: 46
Member: 168352 Status: Offline Thanks Meter: 18 | Quote:
and then rebuild IMEI | |
The Following User Says Thank You to viks For This Useful Post: |
Nokia 3310 Contact Service | nzeiga | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 18 | 12-18-2008 02:18 |
nokia 3310 contact service | malkjos | Nokia Hardware & Hardware Repair | 11 | 08-19-2004 20:08 |
Nokia 3310 Contact service. | serg796 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-08-2003 12:52 |
Nokia 3310 Contact Service | MrHazeem | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 12-12-2002 17:25 |
Nokia 3310 Contact Service | Williamcwy | Nokia Hardware & Hardware Repair | 1 | 02-06-2002 13:51 |
