Nokia 3310 Displays "Not Charging" When I put charger pin into Nokia 3310 it displays "Not Charging" ... Some Body help me... |
So because you are a newbie you have to learn to use SEARCH button ! you will find your answers ! |
1. your charger is working not properly 2. you have a CHAPS batery charger damaged or unsoldrered 3. you have a brocken pcb circuit and try to verify the other answer's to same pb |
Not charging 1 Attachment(s) Try to change V201, posible short... Look Attachment :confused: B.R. |
just remove the vdr. 100% works many times |
Sir COMPAQ, what do you mean by vdr? |
mates not all not charging in the phone is a hardware problem let me share to you what i do first before opening to do hardware first i test the battery terminal with multitester b+ to gnd it should be 3.6v if not its hardware. i use wintesla energy management and run it you'll see not charging will vanish upon running it its too easy than opening the phone i've tested it and use it for a long time especially nokia 33 series. |
@aadil268... check this site- www.centralpark.net.au |
could you please elaborate on wintesla energy management |
sir for me, its simply a very good software and its really effective. energy management calibration is one of its function, base on it function and explanation on how to run it. wintesla is a software that can possibly putting the values of its component to its normal function. easy to say, it can correct a small problem or values differences to a standard values or funtion. |
search button ussssssssssssse! |
I have wintesla software but when i try to run it then it gives error nokia dongle not found.I m using normal flashing cable in paralll port.Can any one help me where is the problem?????? |
3310 not charging When I put charger pin into Nokia 3310 it displays "Not Charging" tried all the solution of this form still same problem pl can anyone try to explain with circuit diagram for tracing the problem ,as nobody tried deeply to solve the problem as this is serious fault in nokia 3310 |
sir, if it is possible to try voltage tracing with circuit diagram as aid while charger is still plug then you'll probably trace where the problem is. |
