Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 10-07-2004, 11:04   #1 (permalink)
.:.GSM-ANGEL.:.'s Avatar
Member: 69984
Thanks Meter: 170
Question Nokia 3310 Displays "Not Charging"
When I put charger pin into Nokia 3310 it displays "Not Charging" ...
Some Body help me...
The Following 3 Users Say Thank You to .:.GSM-ANGEL.:. For This Useful Post:
Old 10-07-2004, 13:41   #2 (permalink)
Ciubaka's Avatar
Member: 42304
Thanks Meter: 12
So because you are a newbie you have to learn to use SEARCH button !
you will find your answers !
The Following User Says Thank You to Ciubaka For This Useful Post:
Old 10-07-2004, 21:17   #3 (permalink)
Member: 73571
Thanks Meter: 2
1. your charger is working not properly
2. you have a CHAPS batery charger damaged or unsoldrered
3. you have a brocken pcb circuit
and try to verify the other answer's to same pb
The Following User Says Thank You to micutu For This Useful Post:
Old 11-14-2004, 19:29   #4 (permalink)
MihaiGsm2003's Avatar
Member: 62032
Sonork: 1582666
Thanks Meter: 189
Not charging
Try to change V201, posible short...
Look Attachment
B.R.
Old 11-15-2004, 14:37   #5 (permalink)
COMPAQ's Avatar
Member: 18462
Thanks Meter: 30
just remove the vdr. 100% works many times
Old 11-16-2004, 09:59   #6 (permalink)
Member: 35245
Thanks Meter: 3
Sir COMPAQ, what do you mean by vdr?
Old 11-18-2004, 16:11   #7 (permalink)
Member: 77055
mates not all not charging in the phone is a hardware problem let me share to you what i do first before opening to do hardware first i test the battery terminal with multitester b+ to gnd it should be 3.6v if not its hardware. i use wintesla energy management and run it you'll see not charging will vanish upon running it its too easy than opening the phone i've tested it and use it for a long time especially nokia 33 series.
Old 11-19-2004, 01:48   #8 (permalink)
Cheater -Don't Deal with him-
abbeydguru's Avatar
Member: 23994
Thanks Meter: 42
@aadil268... check this site- www.centralpark.net.au
Old 12-04-2004, 13:24   #9 (permalink)
Member: 54469
could you please elaborate on wintesla energy management
Old 12-06-2004, 14:40   #10 (permalink)
Member: 77055
sir for me, its simply a very good software and its really effective. energy management calibration is one of its function, base on it function and explanation on how to run it. wintesla is a software that can possibly putting the values of its component to its normal function. easy to say, it can correct a small problem or values differences to a standard values or funtion.
Old 12-23-2004, 16:57   #11 (permalink)
crisrad's Avatar
Member: 98823
Sonork: 100.78833
Thanks Meter: 9
Old 12-26-2004, 23:37   #12 (permalink)
pava's Avatar
Member: 80567
Thanks Meter: 48
search button ussssssssssssse!
Old 01-01-2005, 06:30   #13 (permalink)
cellco_mann's Avatar
Member: 78448
Thanks Meter: 17
I have wintesla software but when i try to run it then it gives error nokia dongle not found.I m using normal flashing cable in paralll port.Can any one help me where is the problem??????
Old 01-03-2005, 18:43   #14 (permalink)
Member: 85008
Thanks Meter: 4
3310 not charging
When I put charger pin into Nokia 3310 it displays "Not Charging" tried all the
solution of this form still same problem pl can anyone try to explain with circuit diagram for tracing the problem ,as nobody tried deeply to solve the problem as this is serious fault in nokia 3310
Old 01-06-2005, 08:04   #15 (permalink)
Member: 75632
sir, if it is possible to try voltage tracing with circuit diagram as aid while charger is still plug then you'll probably trace where the problem is.
Nokia 1100 start up display "not charging" ammhai Nokia Hardware & Hardware Repair 5 02-20-2010 18:01
Nokia 7610 shows "not charging".plz help. jana1_2008 Nokia Hardware & Hardware Repair 19 07-24-2009 12:44
6111 displays "not charging" André_F Nokia Hardware & Hardware Repair 7 03-13-2008 15:00
5100 displays "not charging" zullu2004 Nokia Hardware & Hardware Repair 0 11-27-2006 09:39
Nokia 3310 says "not charging" even with new charger mmjulian Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-23-2006 03:47
Page generated in 0.44925 seconds with 9 queries
