06-24-2003, 20:30 | #1 (permalink) |
Junior Member Join Date: Jun 2003
Member: 32417 Status: Offline Thanks Meter: 0 | Nokia 3310 USB Data Cable When i try to use programs such as LogoManager or Oxygen PhoneManager II they cannot connect to my phone via USB. I only get options for COM1 COM2 COM3 etc... Do i need drivers of some sort? I didn't get nothing with the cable, just the cable itself. If i do need drivers where can i download them? Please Help Thanks |
07-03-2003, 09:45 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | yeah, i have seen that cable but didnt used it.... look for some port emulators... there are some soft which will emulate ur usb as COMM9 or COMM10,, eg. then logomanager shud work and also other softs.... Naman |
07-04-2003, 03:45 | #6 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Shenzhen, China
Member: 7911 Status: Offline Thanks Meter: 7 | Most of the cables that plug into USB ports are just standard serial cables with a USB converter attached. The standard bridge chip is a "Prolific PL-2303" - if you go to http://tech.prolific.com.tw and search for "PL-2303" you should be able to download the drivers for your OS. You might have to find the device (probably under unknown devices in hardware manager) and tell it to reinstall the driver. |
07-04-2003, 12:58 | #7 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | i got this data cable a few days ago but this was marked for 3350 (the connectors are same as 3310) but i didnt try it...i think it will work, there is a CD with this cable which contains drivers for USB.. then it may connect with logomanager... Syed |
01-05-2005, 21:01 | #9 (permalink) |
No Life Poster Join Date: Mar 2004 Location: South Coast UK
Member: 58075 Status: Offline Thanks Meter: 17 | I sell 3310 USB cables, logomanager works fine with prolific driver, nokia data suite has problems though I never got it to work with serial emulator |
02-04-2005, 06:05 | #10 (permalink) |
Junior Member Join Date: Jan 2005 Age: 45
Member: 111783 Status: Offline Thanks Meter: 0 | Quick Question... About the Nokia 3310/3330/3410 serial data cable. Now, I want to reflash my 3310. But, If this cable fits under the battery... Then the battery just piggybacks off of the cable? If so, Can I reflash my phone using this cable? |
02-04-2005, 06:57 | #11 (permalink) |
Freak Poster Join Date: Oct 2002 Location: GHANA-ACCRA Age: 44
Member: 17080 Status: Offline Thanks Meter: 1 | wellcome why there are lockers that lock the batt when you insert. so check it well to hold like 3310 batt in a phone if no pasibble use your hand to hold it tight on it or put something thecnicaly to hold it for to be able to do the work GOOD LUCK |
02-04-2005, 07:10 | #12 (permalink) |
Member: 17080 Status: Offline Thanks Meter: 1 | HI MR TRIMESH UR URL CANT CONNECT WHY I MEAN http://tech.prolific.com.tw IS NO WORKING |
02-09-2005, 21:14 | #14 (permalink) |
Junior Member Join Date: Feb 2005 Location: INDIA Age: 39
Member: 112441 Status: Offline Thanks Meter: 0 | new PC suite with USB support required to use DKU 5 cable hey guys, If u r facing problem with DKU-5 cable. Don't worry. Just uninstall ur PC suite provided by Nokia and install new PC suite from the DKU-5 drivers CD The Pc suite on DKU-5 driver's CD is advanced. Nokia's Pc suite 5.0.1 doesn't provide USB support whereas new PC suite (5.8 for win98 & 6.4 for win XP ) supports USB feature I hv tested it with my phone -PAK |
what other usb data cable compatible for Nokia 1680c? | shiver21 | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 01-08-2009 09:01 |
Hi everybody... i have a usb data cable of nokia and... | samsung man | Nokia Multimedia | 2 | 10-11-2004 04:55 |
Nokia 6600, USB data cable and PC SUITE | Ramay | WD2 & APE (Symbian Phones) | 1 | 08-17-2004 22:19 |
Nokia 3310 USB Data Cable | mld | Nokia Hardware & Hardware Repair | 6 | 08-02-2003 21:23 |
