01-20-2002, 06:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: China GuangDong
Member: 7220 Status: Offline Thanks Meter: 1,592 | Any Solution for auto 4 locks for 3310? I had came across 2 sets of 4 locks for the Nokia 3310. and all cases are geniune without using any flasher or software before. Whats wrong with it. The imei is intact. 4 lock in FFFFFF closed mode. Tested it on the Nokia Tool. Some people saying that it is the Cobba faulty. But how to solve it? Any solution without changing the cobba. Can I use a full flash or upgrading to remove it? <br />Regards<br />Alan <img src="eek.gif" border="0"> <FONT COLOR="#ffff00" SIZE="1">[ 20 January 2002 06:03: Message edited by: xpmobile ]</font> |
01-20-2002, 08:19 | #2 (permalink) |
Product Supporter Join Date: Jan 2002 Location: Philippines
Member: 8303 Status: Offline Thanks Meter: 127 | it happened to me many times, ur error is you overwrite the original eeprom contents our fone. all u can do is upload the original eeprom which i think u have a backup. |
01-20-2002, 09:35 | #3 (permalink) |
Member: 7220 Status: Offline Thanks Meter: 1,592 | Hi, Thanks alot. But this isn't caused by that. The phones just stated "SIMCARD NOT ACCEPTED" while coming out from the lift and network search <img src="eek.gif" border="0"> <img src="eek.gif" border="0"> <img src="eek.gif" border="0"> . This is an X-FILE that I ever came across Regards<br />Alan <br /> <img src="eek.gif" border="0"> <img src="eek.gif" border="0"> <img src="eek.gif" border="0"> |
01-21-2002, 18:27 | #4 (permalink) |
Freak Poster Join Date: Nov 2001 Location: india
Member: 7176 Status: Offline Thanks Meter: 0 | hai my friend try unlocking using nu3000 or jethro6.22...if not solved its due to cobba chip complaint...try rehoting the chip.<br />please feel free to contact me for any kind of help..... [email protected] |
01-22-2002, 02:55 | #5 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Leiria, PT & *******, CN
Member: 3756 Status: Offline Thanks Meter: 5 | Hi! I once had a 3310 with all 4 locks closed but IMEI intact.... I reflashed the same MCU+PPM (so that i don't have to calculate FAID) and hoted the phone...<br />I also reseted the phone to factory defaults...<br />After that phone was ok...! C ya! |
01-22-2002, 05:40 | #6 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | [quote]Originally posted by xpmobile:<br /><strong>Hi, I had came across 2 sets of 4 locks for the Nokia 3310. and all cases are geniune without using any flasher or software before. Whats wrong with it. The imei is intact. 4 lock in FFFFFF closed mode. Tested it on the Nokia Tool. Some people saying that it is the Cobba faulty. But how to solve it? Any solution without changing the cobba. Can I use a full flash or upgrading to remove it? <br />Regards<br />Alan <img src="eek.gif" border="0"> </strong><hr></blockquote> Hi, This is very common problem. There is this start up self test which check the Cobba parallel interface, but it;s look like the test is not reliable enough. This could happen if you have broken ball under Cobba ( loose conn. ) or more possible some small <br />quantity of water under the chip. So the the data still flow between the DSP and Cobba , but small impedance between data pins cause errors one security data and locks are calculated wrong. Observe Cobba carefully, rework, clean, reball or even change. Best Regards, Alex |
@lead any help for k700 4 locks? | hrco | Cruiser Suite | 7 | 03-25-2005 17:55 |
still no solution for t65 4 locks | misel | Sony Ericsson | 0 | 11-17-2003 08:12 |
Is there any solution for 3330 4 locks on EEEEE FFFFF??? | mashco | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 12-24-2001 14:04 |
Need To Open 4 locks in 3310 | Egypt Unlocker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 12-04-2001 18:28 |
best solution for auto turn off on 3310 | mudboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-18-2001 20:05 |
