05-08-2002, 13:39 | #31 (permalink) |
Freak Poster Join Date: Feb 2002 Location: singapore Age: 46
Member: 9194 Status: Offline Thanks Meter: 3 | I had post before.. Used only NK Calc to clear SP lock and Update FAID If you want to change IMEI used Rolis 1.7B and than NK Calc to do FAID update.. F3 F2 F1, Eeprom Tools and Rolis 1.7B result no network in 20-30secs.. because of differrent algorithm in decoded IMEI Try NK CAlC sure you got back NETWORK |
05-08-2002, 15:27 | #33 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Tutuban Age: 68
Member: 10635 Status: Offline Thanks Meter: 10 | josaic, yes you can use Rolis 478, it flashes the whole frm 20-40 then change IMEI, SP locks the FAID Update... But my problem no network ,someone said must use NK CALC, but I don't have pure MBUS cable to do it...;-( BR, Epic |
05-08-2002, 15:59 | #34 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Mauritius Age: 47
Member: 7482 Status: Offline Thanks Meter: 24 | Working 100%%%%%% Use Knok (build 22) You can use any flasher and use Knok ( build 22 ) to 1 change IMEI 2 update FAID 3 Reset SP locks Tested by me on several phones. Working 100%%%% You can use DUAL MBUS/FBUS cable. No need to have pure MBUS to update FAID. TRY and post results!!!! |
05-08-2002, 20:39 | #38 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Nokia Age: 44
Member: 11395 Status: Offline Thanks Meter: 3 | Hi all... I used Knok22 and it worked 100%. I have two questions: 1. Did anybody try to change the security code? I tried, it only work one time then gives you "Code Error". any solution? 2. Is there any chance of an Arabic PPM for the 3315? Maybe in the futur? Thanks.. |
05-08-2002, 21:03 | #39 (permalink) |
Member: 9194 Status: Offline Thanks Meter: 3 | Used Rolis 1.7B to Software Reset and Set Factory Setting but after you done you will get no network in 20secs to 30secs intermitent and re updated FAID |
05-08-2002, 22:07 | #40 (permalink) |
Member: 11395 Status: Offline Thanks Meter: 3 | I used Knok22 to Reset Software and Set Factory Setting but I lost the Picture editor. I used EEPROM 3.1 by B-phreaks but also lost the editor. Will the Rolis disable the editor too? Thanks alot... |
05-08-2002, 23:04 | #41 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Earth Age: 44
Member: 10281 Status: Offline Thanks Meter: 4 | I did make one 3310 3315 today thanks to Lasse Hedegaard -who sent me the file and works ok. I flash it with Rolis 5.14 Nk_calc.F1 F2 F3 And eeprom tools 3.01 only update authority id,The first one from the left.If you make Fix Imei And Unlock with eeprom tools you will lost the extras and will be like 3310. Regards Visar |
05-08-2002, 23:47 | #42 (permalink) |
Junior Member Join Date: Mar 2002
Member: 10247 Status: Offline Thanks Meter: 0 | i ll make a custom PPM with english and italian language. How i can insert italian dictionary for T9? I have tested with 3310 v4.45 dictionary and PPM Manager 0.91 is death :-( Hlp me, please :-P |
05-09-2002, 04:37 | #43 (permalink) |
No Life Poster Join Date: Jul 2001
Member: 5243 Status: Offline Thanks Meter: 80 | 3310-3315 Here is my method: 1) Flash the phone using knok22, 2) Update faid with bphreaks 3.1 3) Unlock with bphreaks 3.1 4) Change original imei with nse imei by pro, 5) Change imei using rolis 1.7. Then the phone should be 100% working Anyone else care to test? Regards Alex |
05-09-2002, 05:21 | #44 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Brno, Czech republic
Member: 7446 Status: Offline Thanks Meter: 1 | And here is my method: 1) Flash the phone using knok22, 2) Change imei using knok22. 3) Unlock with knok22 4) Update faid with knok22 (quick set FAID) Easily with one program... works 100%. Best Regards, Hans |
Wanted!!!! Orig Housing for Nokia 3315 | khansa | Wanted Products | 0 | 04-21-2003 20:49 |
Nokia 3315 Network | Xanga | Nokia Hardware & Hardware Repair | 2 | 01-30-2003 23:02 |
nokia 3315 | shockboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-14-2002 17:42 |
Nokia 3315 ORGINAL Keypads wanted. | Nanda | Wanted Products | 0 | 10-24-2002 00:57 |
Nokia 3315....For All Who Interest | Trebor | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-28-2002 04:48 |
