Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 10-24-2010, 08:47   #1 (permalink)
Faheem Anjum's Avatar
Member: 399832
Wink nokia 5030 security code !
today i share here small problem 5030 security code not remove with any method > really i am also wondering about this problem
i have a set nokia 5030 security code !
simple i reset the set but not remove code
then flash still same not remove code
then full erase the set then full flash still same
then unlock and write Pm file again Ui setting still same
So have any other way to solved this problem ?
problem is so simple but strange
Old 10-24-2010, 08:51   #2 (permalink)
Member: 817970
Brother This is Hardware problem
pasting on UEM
Old 10-24-2010, 08:52   #3 (permalink)
Member: 328688
most of time when i cant reset i do full erase and flash with jaf working 100 for me
Old 10-24-2010, 08:53   #4 (permalink)
Member: 903738
try to read code by mx key or this problem of from keypad
Old 10-24-2010, 08:53   #5 (permalink)
Member: 699543
Sallam
u wana read code or remove it ....
just read it and remove or change it with ufs....
Old 10-24-2010, 08:57   #6 (permalink)
Member: 399832
read my post again already full erase it then full flash still same
Old 10-24-2010, 09:08   #7 (permalink)
Member: 399832
Sallam
mx key not read the code i manual set the code but not working check my fst post
Old 10-24-2010, 09:10   #8 (permalink)
Member: 328688
did u try with jaf if u try post log here and if still same then hardware problem
Old 10-24-2010, 09:10   #9 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Bro I suggest once try using phoenix, connect phone via com cable and than do full factory setting by phoenix.
WBR
Old 10-24-2010, 09:15   #10 (permalink)
Member: 399832
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30118
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.31.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 03.75
21-04-09
RM-524
(c) Nokia
HW version:
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w06_UPP
LCD version: INNO:BOHAIv90
NT39121
PPM version: V 03.75
21-04-09
RM-524
(c) Nokia
IA
ADSP SW version: V 03.75\n21-04-09\nRM-524\n(c) NMP\nia
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356074038433806
IMEI spare to net: 3A 65 70 04 83 34 83 00
IMEI SV to net: 33 65 70 04 83 34 83 20 F6
Master Code: 2256003155
Phone type: RM-524, Software version: 03.75, Language Pack: IA
User code: ÿ#
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-524.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code:
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-524\
Searching for default location of ini...
Checking path: \Products\RM-524\
Searching for JAF saved location of ini...
No ini files found...
Done!
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 6 seconds...
Done!
Resetting USER DATA...
Operation took 0 minutes 0 seconds...
Done!
Resetting LEAVE FACTORY...
Done!
Resetting SERVICE CENTER...
Done!
Resetting UPGRADE SOFTWARE...
Done!
Resetting PRODUCTION TUNE...
Done!
Old 10-24-2010, 09:15   #11 (permalink)
Member: 699543
Oh woh thats great then do 3 works then ur set will be ok
1 : Send this mobile to me i try on it ....
2: Return mobile to its owner .....
or
3 : othere wise put this mobile on a road and hit with it stone
na rha ga sanap na bjaa gi bansri .......
never mind just jokeing
i do many set with ufs maunaly just read code
option is Pm edit and just pm info and code is there ...
Old 10-24-2010, 09:16   #12 (permalink)
Member: 399832
WBR
i think phoenix and mt box same flasher ????
Old 10-24-2010, 09:29   #13 (permalink)
Member: 328688
or
u make me laugh
Old 10-24-2010, 09:31   #14 (permalink)
Member: 687312
Maybe it was just an experience that I shared once I got a 6020 that had security code but it didn't detect via fbus cable so I connected via com cable and Did full factory setting. anyway I hope you solve it soon.
Good Luck
Old 10-24-2010, 09:53   #15 (permalink)
Member: 399832
Good Luck
both not same problem my set flashing unlocking resting all working fine but still same problem apper code not remove . maybe hardware problem but i am wonder and fst time i am looking like this . maybe its also write in world book about this set ...that after all method use still not remove the code
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.40443 seconds with 11 queries
