02-27-2001, 07:44 | #1 (permalink) |
Freak Poster Join Date: Feb 2001 Location: Bacolod, Philippines
Member: 3360 Status: Offline Thanks Meter: 4 | !!!DANGERS WHEN FLASHING PHONES!!! Upload was successful but phone is dead! It can't be reflashed back since the phone wont even respond to turning it on (battery is full, tried on a separate 5510). Phone is now only good for salvaging some components like sim holder, battery, flash, eeprom, etc. I suspect that the flash I uploaded was not compatible to the processor on the phone itself. Or the original address where the processor is pointing in order to operate the phone properly now has an invalid entry point. Thus a dead phone. Nope, I'm not crying for help on how to fix it. Only way to fix this is by sacrificing another 5110 with working flash, eeprom and cobba which is equivalent to buying another phone without worrying if it'll work or not. Let this serve as a warning to experimenting with flashing your phones with different flash/firmware: ! ! ! DO NOT FLASH YOUR PHONES WITH OTHER FLASH FILES ASIDE FROM THE SAME VERSION ! ! ! Best regards to all. |
02-27-2001, 08:51 | #2 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | This is a weird situation... But I dont entirely agree with what you say. Maybe phone have other problems in the First Place because even if you erase full flash from phone, Dejan flasher will still detect it. I even uploaded 6110 flash file to a 6138 phone, and phone powers on but all locks are closed off course... |
02-27-2001, 09:52 | #3 (permalink) | |
Member: 3360 Status: Offline Thanks Meter: 4 | Quote:
"Done!" it said. But the phone wont turn on. Won't respond to a reflash, or a power on. | |
02-27-2001, 10:41 | #4 (permalink) |
Member: 3360 Status: Offline Thanks Meter: 4 | BTW, X-Shadow do you still have a copy of that schematic for the Pony Prog? The one that can read/write the 24Cxx without desoldering? Thanks in advance... |
02-27-2001, 12:43 | #6 (permalink) |
Member: 871 Status: Offline Thanks Meter: 602 | Starting 3210 v5.36 (and some of v5.31) and 5110 v5.30 (and some of v5.28 and v5.29) You need to desolder EEPROM already, but for lower versions, you can read and write without desoldering, just plug charger to phone even without battery and connect any EEPROM TSOP adapter. Best Regards, X-Shadow |
02-28-2001, 02:04 | #7 (permalink) | |
Thanks, you were been a great help to everybody. You and the helpful moderators here. | |
02-28-2001, 04:44 | #8 (permalink) |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Hi Ice Dragon I Totally agree with X-Shadow you can throw any full backup at any phone and the worst case senario will be "Software ASIC Mismatch which basically means wrong software for this version of phone, all I could think it could be is a flat battery, or you should remove battery, even when flash is absolutly empty on production line the phone will still respond to flashing, even though its faster flashing than we do at 12Volts, or maybe as X-shadow said this phone has another problem. I have some scrap phones that I have reflashed and played around with scores of times with no problems that you have got, even the same version as you 5110-5-28 flashed with 4.51 and it still responds Hope this helps mate Regards Charlie |
02-28-2001, 07:10 | #9 (permalink) | |
I got hold of another fully charged battery and put it on the dead phone, still no response. You see, my problem is if I could not put the phone to respond to a power on when flasher asks for it, it could not proceed to re-flashing it back. It displays the message "Phone not respond" since it does not indeed respond to power on. I tested the flasher cable with another 5110 and works fine. Read or upload. Full or partial. Everything's fine. Except, I didn't flash the other phone with another 4.51 version, coz I'm afraid it will kill the other phone too. Didn't experience any power surge either. PC is on UPS. Oh well, that's that. Thanks all and best regards. | |
02-28-2001, 10:32 | #10 (permalink) |
Crazy Poster Join Date: Feb 2001 Location: Westcoast, Poland
Member: 3299 Status: Offline Thanks Meter: 0 | You can read/write eeprom from old phones (without eeprom emulation) with this prog by Mbus cable. http://nuggie.republika.pl/NokiaSP.zip |
n95 phone lock when flash phone start up failed | imran_4_u | Nokia Hardware & Hardware Repair | 1 | 02-14-2009 10:54 |
why is it when i prepare phone i have to flash phone | smart phones | Smart-Clip | 3 | 02-04-2007 02:01 |
got error when flashing phone | ddhorn | WotanServer | 10 | 12-09-2006 17:09 |
USB SMART - When flashing phone do you select all three files and tick complete | shahzad9 | SonyEricsson (USB-Smart) | 4 | 12-16-2005 16:14 |
When flashing phone do you select all three files and tick complete phone or | shahzad9 | SonyEricsson (USB-Smart) | 0 | 12-16-2005 00:20 |
