Nokia 6150 5.02 Stupid Security Code!!! Can anybody help me? Unlock a this 6150 i opened all locks then it asked for the security code so i read it and when i insert it returns wrong code, then i use the cyberphreack all nokia software that make a reset to 12345 and it didn't work, even in wintesla, i put a new security code, but then it returns again wrong code... So can anybody help me with this problem?? There is any eprom sollution that i can desactivate the security option, without turn on the phone? |
mmmm....5.02....logomnager would simply do the trick. but what sec code are you referring to here....is dis the typical sec code of the phone??? you can also reset or view this using nokia tool ------------------ |
My problem is that i already have the security code (normal one), and locks(1,2,3,4) are all open. then when i put a card it ask for the security code, i put the right code and it returns wrong code, but How.. This already apened to me with a 5110 but then i changed the code, and when i put the new one the phone acepted. But this old 6150 don't acept the old or the new code, it returns every time wrong code after reading him with wintesla, cyberphreak or other progs... So I'm asking if there is somebody that know how to solve this problem, or any solution for eprom(desactivate the security option). |
with wintesla simply set the factory default and the lock code will be reset to 12345 and off |
Ringnet, r u sure its the security code and not the PIN code or PUK that u r after??? K Of K |
there are only 5 possibilities of entering the correct security code. if you enter 5 wrong codes, the phone stops accepting every codes, even the right one (but keeps asking it) on old nokias (3110, 8110 and older) it was possible to generate (with only the imei)a 10 digit mastercode to unlock the security code. (never tested it, but wintesla gives that mastercode, for example in 8110, on "User settings" menu) however, on new nokias, you need to reset the UI settings, using wintesla or PcLocals. it will turn off the code and set it to 12345 |
You can also do this with nokia tool by pro, CyberPhreaks All Nokia program and Nokia AllOne by DarkTelecom. |
Thank you all, by the big help... The GSMdude tip was cool, with the wintesla reseting the phone... But I advice you that Cyberphreak all nokia didn't work (didn't reseted the phone). And Flipo I didn't know that the 5 atempts work with the security code, i thought that was only with the master codes(thanks)... Best Regards, by the way this is the best gsm Forum that i know. |
the reset of all this programs brings the mobile only in normal mode!!! this is not a reset of the software... think clear of this ;-) if the mobile hangs on any menu or point, just do the ui reset or the factory reset on wintesla thats the only way!! WinTESLA = WINDOWS Test and Service Locals Application |
Or even easier , run PC Locals v1.3 and choose options 3 and 3 again , thsi will reset to factory values!! http://www.thoic.com/gsm/ubb/wink.gif |
