Nokia 6210 "security code" Hello, i have a problem with Nokia 6210 : in phone was soft v3.04, on power on asked "security code", i flashed phone with rollis (mcu + ppm), update FAID, clear SIM Locks etc with noktool by jordic, but again on power on "security code", i tryed wait 15 min, then enter "right" code (readed with noktool by jordic), but without success - "wrong code". How to resolve this problem? Any ideas? Thanks for help. P.S. sorry for my bad english |
1 Attachment(s) Here is Virgin eeprom, see atachment! |
no no no guys .... only what u have to do is : 1. write code 12345 2. setup, security settings, change access codes, change sec. code from 12345 to 12345. 3. change security level. that s all. U cant do anything else because cell tell CODE ERROR´. I have this problem with all 3310 when i make 3315. It is because u update faid. NICE day :D |
If you read the corect secutity i think you mast wait 30 ' or long , type code... end the problem!!! |
sorry guys but in 6210 if you entered the code more than 10 times the phone will block it self and you have to clear the security counter by knock phonix or write a good 4mb flash file (MCU + PPM + Eprom) |
Hi Guys Got Also A 6210 Failing To Reset The Security Code Got The Virgin Eprom Off Vrba Thanks But What Program Do I Use With It |
You Are All Wrong You can try software for a million times, but phone will never unlock. You get the right code with rolis, etc, but when you inpute it, it says wrong code. Well this is 100% bad CCONT problem. It probably has bad soldered balls under. If you can, reball ccont, and your phone works again. To confirm what I said, ask the owner of that phone, he will probably tell you he NEVER used code on that phone; the phone just woke up one fine day and started asking for code. This is common wit 6210 8210 5210 Remember, if you cannot reball, DONT TRY IT, otherwise phone will die, and customer will tell you to "RETURN IT THE WAY IT WAS, MY COUSIN SAYS HE CAN UNLOCK IT UNDER 1 MINUTE" |
This is Correct As far as I am concerned the Security Code of 6210 can be removed only with WinDLS. Try WinDLS and you may succeed. WBR |
Use "Knok Phoenix Build 1a" for example. There's option "clear security code counter" you must reset counter when you put wrong code more than 10 times. Good luck. BR ZG |
try to repair with nokia dct3 calculator, then read with logomanager. if don't work, try with nokia tools 23 to aply sfs all positions ( one by one) |
YES IT WORK, tested by me ! |
write the new eprom -unlock and sim lock by ufs3 100% -other program 50% try |
this eeprom is too small, whith rollis I've still an error message "File size must be n*64KB (n=1,2,3 ...)". What can I do? |
1 Attachment(s) Use this software. Using Rolis, read eeprom from 05A0000-0600000. Run software and open flash file you just backed up, then save the file. Open the new eeprom file in rolis and write to 05A0000. Job Done. 6210, 6250 and 7110 Security codes cannot be reset like other DCT-3. This is the one of th only SAFE ways to do it. |
