Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 01-22-2004, 19:15   #1 (permalink)
AGr
Member: 48927
Nokia 6210 "security code"
Hello,
i have a problem with Nokia 6210 :
in phone was soft v3.04, on power on asked "security code",
i flashed phone with rollis (mcu + ppm), update FAID, clear SIM Locks etc with
noktool by jordic, but again on power on "security code",
i tryed wait 15 min, then enter "right" code (readed with noktool by jordic), but without success - "wrong code".
How to resolve this problem? Any ideas?
Thanks for help.
P.S. sorry for my bad english
Old 03-26-2004, 12:51   #2 (permalink)
Member: 51184
Originally Posted by AGr
Hello,
Thanks for help.
you must write the eeprom with an virgin eeprom file, after that you make update faid and the security code will be 12345
The Following User Says Thank You to robert_kcs For This Useful Post:
Old 03-27-2004, 19:44   #3 (permalink)
vrba's Avatar
Member: 3538
Here is Virgin eeprom, see atachment!
The Following User Says Thank You to vrba For This Useful Post:
Old 03-27-2004, 20:25   #4 (permalink)
Member: 59573
no no no guys .... only what u have to do is : 1. write code 12345
2. setup, security settings, change access codes, change sec. code from 12345 to 12345. 3. change security level. that s all. U cant do anything else because cell tell CODE ERROR´.
I have this problem with all 3310 when i make 3315. It is because u update faid. NICE day
The Following User Says Thank You to fesak417 For This Useful Post:
Old 03-28-2004, 00:42   #5 (permalink)
suy
Crazy Poster
Member: 49792
If you read the corect secutity i think you mast wait 30 ' or long , type code... end the problem!!!
The Following User Says Thank You to suy For This Useful Post:
Old 04-02-2004, 01:05   #6 (permalink)
Member: 17337
sorry guys but in 6210 if you entered the code more than 10 times the phone will block it self and you have to clear the security counter by knock phonix or write a good 4mb flash file (MCU + PPM + Eprom)
Old 05-20-2004, 22:22   #7 (permalink)
Member: 55062
Hi Guys Got Also A 6210 Failing To Reset The Security Code Got The Virgin Eprom Off Vrba Thanks But What Program Do I Use With It
The Following User Says Thank You to TALLSAJ2 For This Useful Post:
Old 05-21-2004, 10:19   #8 (permalink)
dannyogolo's Avatar
Member: 18200
Sonork: 100.1608286
You Are All Wrong
You can try software for a million times, but phone will never unlock.
You get the right code with rolis, etc, but when you inpute it, it says wrong code.
Well this is 100% bad CCONT problem. It probably has bad soldered balls under.
If you can, reball ccont, and your phone works again.
To confirm what I said, ask the owner of that phone, he will probably tell you he NEVER used code on that phone; the phone just woke up one fine day and started asking for code.
This is common wit
6210
8210
5210
Remember, if you cannot reball, DONT TRY IT, otherwise phone will die, and customer will tell you to "RETURN IT THE WAY IT WAS, MY COUSIN SAYS HE CAN UNLOCK IT UNDER 1 MINUTE"
The Following User Says Thank You to dannyogolo For This Useful Post:
Old 06-25-2004, 10:26   #9 (permalink)
Rahuman28's Avatar
Member: 58172
This is Correct
As far as I am concerned the Security Code of 6210 can be removed only with WinDLS. Try WinDLS and you may succeed.
WBR
The Following User Says Thank You to Rahuman28 For This Useful Post:
Old 06-25-2004, 19:37   #10 (permalink)
Member: 38755
Use "Knok Phoenix Build 1a" for example. There's option "clear security code counter" you must reset counter when you put wrong code more than 10 times. Good luck.
ZG
The Following User Says Thank You to TELE-MEDIA For This Useful Post:
Old 07-20-2004, 17:59   #11 (permalink)
Member: 73571
try to repair with nokia dct3 calculator, then read with logomanager.
if don't work, try with nokia tools 23 to aply sfs all positions ( one by one)
The Following User Says Thank You to micutu For This Useful Post:
Old 08-27-2004, 17:40   #12 (permalink)
Member: 57729
ZG
YES IT WORK, tested by me !
The Following User Says Thank You to uwogsm For This Useful Post:
Old 11-06-2004, 00:12   #13 (permalink)
mohammad2004's Avatar
Member: 71144
write the new eprom -unlock and sim lock by ufs3 100% -other program 50% try
The Following User Says Thank You to mohammad2004 For This Useful Post:
Old 11-19-2004, 16:52   #14 (permalink)
Member: 56335
Unhappy
Hi,
this eeprom is too small, whith rollis I've still an error message "File size must be n*64KB (n=1,2,3 ...)".
What can I do?
The Following User Says Thank You to coupdephonie For This Useful Post:
Old 11-19-2004, 17:08   #15 (permalink)
Member: 14358
Use this software.
Using Rolis, read eeprom from 05A0000-0600000.
Run software and open flash file you just backed up, then save the file.
Open the new eeprom file in rolis and write to 05A0000.
Job Done.
6210, 6250 and 7110 Security codes cannot be reset like other DCT-3. This is the one of th only SAFE ways to do it.
The Following User Says Thank You to surfy For This Useful Post:
Nokia 6800 "Security Code???" madcrowmax Nokia Digital Core Technology 4 ( DCT-4 ) 3 06-20-2008 03:11
6600 "security code" trinacria46 WD2 & APE (Symbian Phones) 6 09-23-2004 17:41
Nokia 6310i "restriction code" bozzoso Phone Unlocking Codes & Maps 10 10-31-2003 08:55
6510 shows "Security code" plz help a.s.a.p the_frightener Nokia Digital Core Technology 4 ( DCT-4 ) 3 05-17-2003 13:05
I have locked nokia 6210 with 5.36 flash. Nokia flasher gives such error: dimon Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 12-30-2001 22:51
Page generated in 0.38896 seconds with 12 queries
