02-02-2004, 17:56 | #1 (permalink) |
Insane Poster Join Date: Aug 2002 Location: essex Age: 59
Member: 14367 Status: Offline Thanks Meter: 3 | nokia 8210 |
The Following User Says Thank You to tim20k2002 For This Useful Post: |
02-03-2004, 18:53 | #4 (permalink) |
Member: 14367 Status: Offline Thanks Meter: 3 | nokia 8210 i may have misled i cannot make or receive calls i hav tried factory reset with cable doesn't seem to work i hav full signal i have used nokia tool |
02-03-2004, 19:52 | #5 (permalink) |
Insane Poster Join Date: Aug 2003 Location: Romania - Galati Age: 41
Member: 36222 Status: Offline Thanks Meter: 0 | may be the antena switch is damaged ! Yor phone does not transmit rf well ! Try to use Nokia-solution ... if does not work ... use the service manual ! |
02-03-2004, 20:20 | #6 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | @20k2002.. I think if u try 1st with eeprom programing ,FAID update , reset factory settings. befor goeing to hardware. If U started hardware , start reflow PA and see results. GoodLuck |
02-06-2004, 01:23 | #7 (permalink) | |
Insane Poster Join Date: Feb 2004 Age: 46
Member: 52430 Status: Offline Thanks Meter: 3 | Medz, pls how doone reflow PA as u mentioned here. Quote:
02-06-2004, 20:58 | #8 (permalink) |
Member: 39601 Status: Offline Thanks Meter: 13 | OK Reflow PA is by aplyeing hot gun to the Power amplefire for melting the solder connecting it to the board , thats in case one of its pins is cracked soldering but in most of cases the ceramic base of the PA wich is carying its components and the trackes between them also cracked , leading to faulty PA. So if reflow didnt gives a result U need to replace it. |
02-08-2004, 12:50 | #9 (permalink) | |
Member: 52430 Status: Offline Thanks Meter: 3 | Ressetting the factory settings Quote:
Pls do u mean resetting from the phonemenu or with computer? i have two 8210s now that switches off after making a call 4 like two minutes. one comes up blank anwill be blinking without any sign of network.d other one switches off on its own after exactly an hour. i,ve tried PA reheating-no result. | |
02-08-2004, 19:53 | #10 (permalink) | |
Member: 39601 Status: Offline Thanks Meter: 13 | Quote:
U said that it is switching off after making a call , That is different cause in that case mostly changing PA is the solution. Besid in fact I cant understand clearly the meaning of (balnk) and ( anwill be blinking ), and that one witch switches off automaticaly , is it the same phone or other one? I need some detailes for each case separately. Thx Br | |
02-24-2004, 20:30 | #11 (permalink) | |
Member: 52430 Status: Offline Thanks Meter: 3 | medz, i mean that one of the 2 phones go off after an hour. the other one blinks, then goes off. currently as at today, i got a 3315 nokia that goes off ,once u make a call it knocks off or first shows battery low. battery good and new. Quote:
02-24-2004, 21:02 | #12 (permalink) |
Member: 39601 Status: Offline Thanks Meter: 13 | @chucky. The one wich goes off after an hour could be a 26Mhz Crystal, Cobba , memoreys ,Or Upp crack. While the rebooteing one is wich blinks then restarts it might be the cobba mainly. But the 3315 it is mainly if U checked the +ve line all clean and good connection , that means PA no doubt . GoodLuck Br |
02-26-2004, 15:55 | #14 (permalink) |
Member: 39601 Status: Offline Thanks Meter: 13 | OK... +ve line is from the +ve pole of the battery (Cleaning) ,battery conector,copper plate faceing it,Then PCB itself if it is clean or not (in acse of water effects on the board). Also C575 (Smoothing and reservoir of the power raile). |
Nokia 8210 v5.25 SIM Lock by Nokia Tool 035 :) | Williamcwy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-03-2002 13:53 |
nokia pc suite for nokia 8210 | mymen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-14-2001 12:32 |
UNLOCKING SOLUTION FOR NOKIA 8210, 7110, 3210, 5110 NEW SOFTWARE FOR MEMBERS FREE!!! | SHARKY | GSM Mobile Links | 2 | 12-17-2000 09:23 |
Nokia 8210 | Salad | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-13-2000 22:27 |
New unlocking method for nokia 8210 , 8850 and other nokias | copyland20 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 06-10-2000 20:33 |
