05-18-2005, 11:40 | #1 (permalink) |
Junior Member Join Date: May 2005
Member: 144250 Status: Offline Thanks Meter: 0 | Nokia 9210i - system locked - HELP NEEDED! I have a nokia 9210i which shows 'system locked - enter code to activate the system' what is the solution to this? I dont know the code, how can I use the phone again? Thanx! |
05-25-2005, 22:36 | #2 (permalink) |
Junior Member Join Date: Jan 2004 Location: Greece Age: 47
Member: 48311 Status: Offline Thanks Meter: 0 | goped19 try to format it ... reset your mobile ( tahe the battery off and then place it back ) after that press SHIFT + CONTROL ( at the same time ) and when the Nikia Logo apears ( the 2 shaking hands ) press F .. then you will see a message asking you if you'd like to format ... press yes .... I AM NOT SURE THAT THIS WORKS.... but un the other hand that's what I would do .. and I think that this might work |
06-16-2005, 11:02 | #4 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | through format problem not solved i try to connect with tornado to unlock and restore factory but tornado show MBus error and can't communicate and also try to use dct3 software to communicate but unsucessfull what's wrong |
nokia e90 phone lock help.... | ArtC | Nokia Base Band 5 ( BB-5 ) | 2 | 10-18-2008 09:57 |
Nec N411i locked. Help needed. | Sir_GsM | FuriousGold | 3 | 05-14-2006 18:41 |
How to know if Nokia 6100 is locked or needs Security Code? | o00ze | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 04-26-2006 14:02 |
nokia 6600 system time help!!! | patrickmehta | WD2 & APE (Symbian Phones) | 3 | 03-20-2004 07:56 |
Nokia 8390 Browser Locked! Help! | nashcrawford | Phone Unlocking Codes & Maps | 1 | 05-22-2003 19:44 |
