11-12-2000, 16:25 | #3 (permalink) |
Freak Poster Join Date: Nov 2000
Member: 2566 Status: Offline Thanks Meter: 0 | I found a programmer at http://www.jdm.homepage.dk/newpic.htm But i don't know if it workd with pony prog. I don't heave this prog can you mail it to me???? |
11-12-2000, 19:41 | #5 (permalink) |
VIP-Member Join Date: Jun 1999 Location: Athens, Greece
Member: 254 Status: Offline Thanks Meter: 7 | Hello to all Ok everybody how wants schematics for PonyProgramer please email me private. I have tested 100% It is two very analysed schematics and one html list of materials. My regards to all. Robby |
11-13-2000, 10:33 | #8 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | To AMTX99, Why 3 5V1 ZDIODES? I think you only need two, one at line going to PIN5 and another at line going to PIN6. You don't need it at line to PIN8 because it is already regulated by you 78LS05 I think we use same scheme, but my values are different like 10K instead of 4K6 and 4.7V instead of 5.1V zeners... I will try to make another EEPROM Porgrammer using your values tonight and compare... Your values sound better, especially for the 5.1 zeners. Thanks... Best Regards, X-Shadow |
11-14-2000, 09:47 | #11 (permalink) |
Member: 871 Status: Offline Thanks Meter: 602 | Hello Guys, Today I tried to read EEPROM from 3210 5.36 and 5110 5.29, I did not succeed! I had to totally remove the EEPROM with hot air solder because removing just pin 1 2 3 4 (GND) did not work! I am sure that previous versions lower than the mentioned aboved can be read without removing EEPROM from phone. But now using the same interface that I've been using fo years now, it doesn't work anymore... I amde some tests (continuity test using multi-tester) and noticed that the readings for pin 8 and Pin 5 are higher on 5.36 and 5.29 compared to a 6138 5.01 and a 6150 4.13! Maybe this is the problem. All pins readings like on PIN 1 2 3 4 6 7 are the same. I am sure that nokia made modifications to the EEPROM layout which makes it harder to prgram on board even with external power (charger) attached to the PCB. Now I always get error 14 or error 11 at Pony Prog 2.01a. To AMTX99, If you have successfully worked with these versions, please share me your info... Best Regards, X-Shadow [email protected] |
11-14-2000, 14:58 | #13 (permalink) |
Member: 254 Status: Offline Thanks Meter: 7 | Hello guys I don't know why you have problems with reading 3210 eeprom. I am using Pony maded from Daniel (Uspu). And I am reading/writing direct from PCB all version, 5.31, 5.36, 6.0. of Nokia 3210. But X-Shadow you have made me crazy 9 hours I spend to unlock one 3210 v 6.0 with your subscriptions (3) with no result. Are you sure ? With my best wishes to all of you Regards Robby |
11-14-2000, 20:42 | #14 (permalink) |
Insane Poster Join Date: Nov 2000 Location: Austria Age: 59
Member: 2463 Status: Offline Thanks Meter: 0 | ok - removing pin5 and reading serial eeprom with eprommer. But now, what to do with this hexdata? Which Byte(s) should be changed to remove simlock. Or is it possible to read correct unlock code for #pw+9999999999+1#??! |
11-15-2000, 14:46 | #15 (permalink) |
Freak Poster Join Date: Aug 2000 Age: 55
Member: 1920 Status: Offline Thanks Meter: 3 | to Diddl many phones like philps .can be unlocked only by eeprom soulation .. but in nokia ,,,you can use the cabel.. reading eeprom before unlocking to rest you phone again ..if you get contact servic ,,,after unlocking .. olso to repaire your phone if you alrady have contact serv. in your phone read the old messages about this problems reg |
pony programmer and xprog programmer instull help | ARAB GSM | CAR Electronics | 2 | 06-02-2007 16:48 |
Schematics For Pony Programmer | tnsupplies | Universal GSM Software | 1 | 07-19-2003 16:58 |
Hi sombody can help me with pony programmer | CHATAR | Universal GSM Software | 2 | 04-14-2002 10:25 |
Pony programmer wanted | kage | Main Sales Section | 7 | 01-10-2002 13:24 |
I want to buy Scheme for TAU | tited | Main Sales Section | 0 | 10-09-2001 04:24 |
