Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 03-30-2001, 04:57   #1 (permalink)
makona's Avatar
Member: 2583
Sonork: 100.88702
Thanks Meter: 201
Post nokia phones with network+full signal then NO SIGNAL AND NO NETWORK NAME .!!
hi friends ,
i got this problem alot , itsn't HW problem ,
i got this with some 8210 , 8850 after removing contact service with eeprom sec checksum FAILD .
- and some other phones 6150 ,3310 .. from customers ...
the phone maybe do it if flashed with wrong ppm or firmware or eeprom .. but everything am sure is ok .. WHY THAT HAPPEN ??
* i can see NETWORK NAME WITH FULL SIGNAL THEN IN SECOUNDS NO-netowrk and no-signal *
p.s : alot in 8210's ....
solution ?
best regards
Old 07-15-2002, 17:23   #2 (permalink)
Member: 11017
Thanks Meter: 2
i have the same pb
the same thing is happening to my phone changed the PA
Saw filter
still the same please help
Old 07-15-2002, 19:00   #3 (permalink)
Member: 12212
did you update the faid?
or, it is possible that the antenna connector has a loose contact.
it is useful to activate netmonitor and under test 01 you can see if the phone is searching for a network. when the signal is very low (a value of 100 up in netmon) the signal level drops.
a netmonitor manual would be helpful in this situation.
Old 07-16-2002, 08:03   #4 (permalink)
Member: 11017
Thanks Meter: 2
Thumbs down hot air gun
i hot air guned the cobba, ccont2i and the hagar NMP
now the reception lats three times the length it used to
but still dropes out i'm starting to give up
as i have changed half of the modules in the phone
i'm sussing that there is a microscopic crack on the circuit.
but thanx for your tip anyways
how did you go with your phones
Old 07-16-2002, 09:31   #5 (permalink)
Member: 11729
hi. b4 doing anyting in the hardware, you must be sure that the software is ok. If you repaird a contact service unit and after doing it you will get a full signal and drop after a few secs. Try this:
1.flash the mcu+ppm+eeprom and after that use
2.knok-phoenix to change imei and quick set faid and use
3.Nk profiles to set default. When using nk profile when you click the set defaults all the button must blink.
Hope it works if not try changing the 36mhz crystal osc and PA.(for 3310,82xx & 8850)
Good luck.....
Old 07-20-2002, 06:35   #6 (permalink)
gorandj's Avatar
Member: 13303
Thanks Meter: 11
flash nokia virgin eprom then use nk_calc from dejan and that`s it! works 100%
Old 07-20-2002, 07:48   #7 (permalink)
Member: 8095
Reheating boards
It is best to use a liquid flux when you reheat any board.
This helps the solder to flow in areas where there are dry joints.
There is a flux available from CPC Electronics
Old 07-22-2002, 16:13   #8 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
GUYS !!!
Do not reheat any components ! Bigger chance is that u will **** them than fix them..
Take it off , make new balls ( or use new component with factory made balls - best solution ) and solder it back.
Flash good firmware+virgin eeprom, restore original IMEI, recalculate simlock data and FAID ( with eeprom tools ) and then use REPAIR IMEI option in eeprom tools ( very important ).
If failure remains use wintesla: file - open - NHM5 ( for 3310, just example ) - RF controls ...
Check TX radio button on window appeared, select TX power level 5 instead of BASE, click apply and close ur phone to monitor ( u should see distortion on screen of monitor if PA, antenna switch and cobba are OK.
If still no RF signal it could be 26 MHz clock or something else..
U can use this procedure for diagnostic also...
As u can see no NOKIA expensive equipment involved LOL
Vule
Old 07-22-2002, 16:20   #9 (permalink)
Member: 11017
Thanks Meter: 2
THANKS GUY FOR ALL YOUR RESPONSES.
I DID NOT GET A CHANCE TO TRY IT YET, A WILL LET YOU KNOW IF I SUCCEED
CHEERS
Can Rebel Sim unlock Nokia Phones with FW 58.58 and above? kooolkat357 Rebel SIM Card 1 03-27-2009 23:11
10 utilites for s60 nokia phones with video ringtone full santaram Nokia Multimedia 0 11-21-2006 02:59
K750i after wather no earphone and low network bmg Sony Ericsson Hardware Repair 3 04-09-2006 16:21
31oo no games and no images after flashing with tornado crisrad Nokia Digital Core Technology 4 ( DCT-4 ) 3 03-03-2005 20:04
Sony P-800 no display and no lights? The phone is working perfect. kingofhearts Sony Ericsson 5 06-18-2003 23:16
Page generated in 0.33689 seconds with 8 queries
