Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 02-15-2003, 18:00   #1 (permalink)
Y2K
VIP-Member
Member: 69
NSE-5 v4.73 update to v5.01, no more power on !!!
hi all,
who have any reason for this update problem?
i flashed with windls 3.5 from version 4.73 to 5.01, at the point after eeprom writing windls asked for power off and on to write flash authority than comes failed couse the power on is after flashing no longer working!
for this while it will no longer power on !
only way to reflash is to use the "forced download" button.
with this i can reflash but always on the same point for power off/on no usefull ending of flash process!
please let me know for a way to get this unit repaired.
Old 02-15-2003, 18:12   #2 (permalink)
Member: 1060
Re: NSE-5 v4.73 update to v5.01, no more power on !!!
Originally posted by Y2K
hi all,
Y2k,
Rolis 4.78 (?) or dejan 1.00 much easy to flash 7110 phone
Willy
Old 02-15-2003, 19:37   #3 (permalink)
Y2K
VIP-Member
Member: 69
@willy
it is not a question of "the easy way"!
dejan or rolis cant work if you cant power on the unit !!!
i try this too... btw i use for this original nokia BBD-3 service battery to get the pull up impulse for power on! but no way!!
PS: this could not be easy, if you first have to rebuild a original flash file from nokia to use it with rolis or dejan ;-))))
Old 02-15-2003, 19:54   #4 (permalink)
Member: 1060
Y2K,
what mean "can not power on that unit" ?
plug charger, or pull high to Btemp or press power on key to disable Watch dog, all can make phone powerup, if you HW and SW is good !
and now, if you think, your phone only SW problem ,, then upper way to 'start" "dead phone" flash , there is no any problem !
, if you need, i can look some "backup" 7110 FLS for you !
Willy
Old 02-15-2003, 20:00   #5 (permalink)
Y2K
VIP-Member
Member: 69
@willy
HW should be ok, couse it was working befor flashing.
pull high to Btemp or press power on key to disable Watch dog!
but no result dejan would not start!!
this would be a way to test a other fls, if you can finde a backup!
Old 02-15-2003, 20:33   #6 (permalink)
Y2K
VIP-Member
Member: 69
@willy
thanks for help!
prob is solved
i do it with a other mcu and windls2.9 and it work now it is up to 5.01!
why ve pro update still ? and need user more power update somonahmed VE-PRO BOX 0 03-14-2010 10:04
NOT work MXKEY on vista sp2 after update to v5 alerene MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 09-27-2009 01:14
Solution to upgrade 7110 from 4.84, 4.88 up to V5.01 banKa Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 03-02-2002 08:34
Page generated in 1.77515 seconds with 11 queries
