Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 02-19-2002, 14:42   #1 (permalink)
Crazy Poster
Member: 3183
To open 4 Locks closed to: FFFFF..EEEE..EEEE..FFFFFFFFFF
Hi All,
anyone have experiencies with repairing this kind of problem on 5110 for example with B-phreaks logger a logs as follows:
How to use Logger v1.7 ...
- To open 4 Locks closed to: FFFFF..EEEE..EEEE..FFFFFFFFFF
For this first make sure that your locks are closed for sure - reset the phone<br />to full factory with WinTesla, NokiaTool or just press Read button in the Logger <br />Check again with NokiaTool the condition of the locks.
You'll need to make sure that IMEI number and IMEI_Programing Data are valid.<br />Insert a working SimCard in the phone, switch it on and tick the TEST DSP <br />check box. Logger will put the DSP in test mode and will start continious <br />reading of one of the ADC's in COBBA - this will show the RSSI Value in the<br />status bar. If everything ok - you will get a reading for about minute and<br />at the end of the test you'll see message : DSP Test OK !
If anything wrong - Message Box will propmpt that you have bad responce from<br />the DSP. This will happen when:
- IMEI or IMEI_program data - corrupted<br /> - AuthorityID not valid<br /> - RF part is faulty ( hardware fault )<br /> - Missing Ariel or no Cell coverage
This Test is not 100% reliable - so make sure that all other reasons are excluded.<br />You need to have a SimCard in the phone !<br />Good idea is to make this test few times - between tryes reset the phone to full<br />factory and switch it off and on again.
If the test is succesfull and you're sure that IMEI is not corrupted -<br />Press Read button in the Logger and save the file. <br />Upload the recalculated file like usual. The condition of Locks will be
Lock 1 Closed to 00101<br />Lock 2 Open to 0000<br />Lock 3 Open to 0000<br />Lock 4 Open to 0000000001
You'll have to unlock the phone in most suitable way and that's it !
<br />FOR ME IT DOESN'T WORK! PLS HELP ME
Old 02-19-2002, 14:54   #2 (permalink)
Freestyler2000's Avatar
Member: 2868
Thanks Meter: 514
Post
Hi zDEnaL
Just curiosity - who recalculates the log file which you update into the phone???
If you do everything properly and made a payment, and have the recalculated file from us.... maybe it is going to work.
Best regards<br />Daniel
Old 02-19-2002, 15:37   #3 (permalink)
Crazy Poster
Member: 3183
Post
Hi Daniel,
you are right... I was trying to recalculate LOG with free soft by -tek-. EEPROM is updated successfully but locks are still closed.
If it helps I'm ready to pay for a good LOG!
<br />BR
Old 02-19-2002, 15:50   #4 (permalink)
Member: 7327
Thanks Meter: 12
Post
hello m8
this info is found all on <a href="http://www.b-phreaks.co.uk/" target="_blank">http://www.b-phreaks.co.uk/</a> page & they can calculate the log 4 u .
<br />kind regards .
GU87 seems to be 4 lock closed jamchat Panasonic 4 10-13-2004 14:30
how to repair 4 locks closed t616 with ufs-2 rushi UFS2 + UFS3-Tornadoflasher 2 01-08-2004 10:53
how to rectify 4 locks closed michaelpas Sony Ericsson 0 06-13-2003 00:23
easy to open 4 locks :) badrobo Sony Ericsson 31 06-13-2003 00:20
Need To Open 4 locks in 3310 Egypt Unlocker Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 12 12-04-2001 18:28
Page generated in 0.16808 seconds with 9 queries
