05-01-2001, 02:18 | #6 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Belgium
Member: 4378 Status: Offline Thanks Meter: 0 | Thanks all yes i flash the phone many time with same version 5.16 from ader phone after flashing not network i flash with the originel backup contact service thas 'is the probleme thanks freinds for help |
05-01-2001, 03:47 | #7 (permalink) |
Insane Poster Join Date: Apr 2001 Location: none
Member: 4056 Status: Offline Thanks Meter: 0 | hello chatar! did you flash your cell from 00200000 - 00400000 well if you did so that is wrong! try to do this: read other fone with same version from 00200000 - 00300000 and then flash it 00200000 as your starting address and power on the fone if CS appears again read again other fone from 00300000 - 003600000 and flash it again make sure you have a backup of your fone. That's it hope this will solve your problem! P.S. if this steps not work you have to upgrade your phone using dejan's MCU & PPM uploader (v103) |
05-01-2001, 18:44 | #8 (permalink) | |
No Life Poster Join Date: May 2000 Location: Malaysia and Singapore Age: 49
Member: 1367 Status: Offline Sonork: 88476 Thanks Meter: 27 | Hi, Try to flash add 00200000 to 0033fff0 on the same version,but don forget to made a backup on 003d0000 to 00400000. Good Luck Vid Quote:
05-02-2001, 03:26 | #9 (permalink) |
Member: 4378 Status: Offline Thanks Meter: 0 | thanks freinds for help the probleme now is i dont have seconde phone in the moment i have only same flash versions of 8850.5.16 fls full dus ik kan not make what you tool me if sombody kan make this backup with same version 8850.5.16 for me t'is a reely verry gently good freind sorry for my language thanks and welcom for all help best regards Chatar |
05-02-2001, 18:09 | #10 (permalink) | |
Member: 1367 Status: Offline Sonork: 88476 Thanks Meter: 27 | Hi, You have original backup **fls for your phone??If you have not need 2nd phone. 1.Flash back original **fls to your phone(you gat contact service on you phone) 2.Read a backup from 003d00000 to 00400000(EEPROM with original IMEI)**don lost it**(if you lost it sorry only TDF-4 can halp you)to 'flash.out'and rename. 3.read 2nd backup from 00340000 to 00400000(that is PPM pack & EEPROM). 4.Now you can flash your phone to new full flash in same versions. 5.Write the 2nd backup(00340000 to 00400000)in your phone.. You can't change you PPM pack(00340000 to 003cff0)between you phone & full**fls file. Try it... It you still have problem send me your full backup**fls,I'll try to help you... Good Luck Vid Quote:
05-02-2001, 18:39 | #11 (permalink) |
Junior Member Join Date: Apr 2001 Location: Id
Member: 4148 Status: Offline Thanks Meter: 0 | I have got the same problem 8210 ver 5.21 To VID What can i do if i don't have a backup full ? btw can i flash the phone from 2 nd phone 200000 to 400000 ? Thanks for your help |
05-02-2001, 18:43 | #12 (permalink) | |
Member: 1367 Status: Offline Sonork: 88476 Thanks Meter: 27 | Hi, No. you can't flash it w/o backup from 003d0000 to 00400000(EEPROM),if you flash it that is only TDF-4 can help you. Good Luck Vid Quote:
05-03-2001, 01:17 | #13 (permalink) |
Member: 4378 Status: Offline Thanks Meter: 0 | THANKS Vid i try to do something if is ok i tel you about this experience if not ok i send to you this originel flash thanks for you help me you are greet men best regards |
05-03-2001, 03:27 | #14 (permalink) |
Member: 4148 Status: Offline Thanks Meter: 0 | To Vid Correct me if i am wrong. 1. backup my phone from 3d00000 - 4000000 2. backup my phone from 3400000 - 4000000 3. flash the phone with backup from 2nd ph from 200000 - 3d00000 4. flash again with original backup 3400000 -4000000 thanks for your help . |
05-04-2001, 12:26 | #15 (permalink) | |
Member: 1367 Status: Offline Sonork: 88476 Thanks Meter: 27 | Hi Amb, No if you have 2nd phone on same vis.only get copy (00200000 to 00340000)from 2nd phone.If you don't have 2nd phone!!My as is 'YES'. Good Luck Vid Quote:
need help for 3110c contact service | parihar | Universalbox | 7 | 02-11-2010 12:36 |
i need help for 5130 contact service | chronic | Nokia Base Band 5 ( BB-5 ) | 6 | 07-24-2009 10:23 |
Need urgent help for 7373 contact service | StRaNgE PeRsOn | Nokia Base Band 5 ( BB-5 ) | 10 | 06-13-2009 09:43 |
i need your help for 5220 contact service | genci titi 2002 | Nokia Base Band 5 ( BB-5 ) | 9 | 04-15-2009 07:20 |
need code for v60 contact service | leonard66 | Motorola P2k | 0 | 11-04-2003 13:44 |
