03-19-2003, 09:30 | #1 (permalink) |
Junior Member Join Date: Feb 2003 Location: Madrid Spain Age: 54
Member: 22537 Status: Offline Thanks Meter: 0 | Possible Solution for bad signature on 8210. it used to work when you have an 8210 (or any nokia mobile) that keeps droping signal for short time and then comes back. The post i found in a forum was the next: "Actually, this is easily and cheaply fixable 9 out of 10 times. you need a torx head screwdriver and some dual-sided soft tape about 1mm thick. Disassemble the 8210 to the print and put pieces of the tape on all the black chips (IC's), except the CPU (biggest one). This fixes most 8210 signal problems. Cause is usually a drop or fall. Good luck with it. " I think that the problem can be in a badly contact due to fallen or thermal enlargements of the mobile. When you put the tape, this creates a presion that closes evil contact. It works perfectly since February 20, this year. Good luck. If you have any doubt ask me. |
full solution for bad cut mc60 here | servtelgsm | Siemens Hardware Repair Area | 25 | 11-12-2007 09:53 |
who can propose me solution for bad code in v56 | ashvin | SwS_SaG_BoX | 9 | 08-10-2006 14:00 |
Any solution for bad product setting for KG245 !!!! | preshaust | HWK | 2 | 07-29-2006 09:02 |
Possible solution for 8210 signal problem | kantusjack | Nokia Hardware & Hardware Repair | 0 | 02-21-2003 13:10 |
Possible Solution for 3210 6.xx ? | Toto | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-18-2000 23:37 |
