Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 07-02-2002, 20:57   #1 (permalink)
Member: 13142
Problem with contrast in 7110
Hello,
I have problem with N7110. I had update software to 5.01 and now I have very bad contrast. I had try with Nokia Profile and Knok21 the contrast change but without success. Maybe can Wintesla help but I don't know where :-/
Perhapse have You other ideas how can I change this contrast? Before update was all ok.
Thanks in advance!
Old 07-04-2002, 15:12   #2 (permalink)
Member: 13142
Re: Problem with contrast in 7110
Can't anyone help me???
Old 07-06-2002, 09:50   #3 (permalink)
Member: 12212
use nkprofile running under win98 or winME. if you run it under winxp or win2K, you cannot move the slider correctly.
Old 07-06-2002, 21:00   #4 (permalink)
Member: 13142
I'll try but first in three weeks (I don't have now this phone). Maybe this is problem because I have used nkprofile under W2k. Thank You!
Old 07-13-2002, 14:35   #5 (permalink)
Member: 13565
use eeprom tools press the 3rd button from the left to fix the eeprom. then do a full factory restore.
I had the same problem with a 3210, i did a full flash then did the above after updating the faid.
let ne know how you get on.
Mobwhizhead.........
Old 07-13-2002, 14:36   #6 (permalink)
Member: 13565
Sorry i cant read
you aint got phone now ooopppsss!
not to worry!
Old 07-14-2002, 01:49   #7 (permalink)
Member: 13142
Originally posted by mobwhizhead
Sorry i cant read
not to worry!
Sorry but I don't undestand You
Old 07-14-2002, 12:29   #8 (permalink)
Member: 13565
sorry wrong thread
Old 07-14-2002, 13:54   #9 (permalink)
Member: 2553
Hi,
I had a lot of problems using Nokia profile as well but when you first run logomanager and then run NKprofile it works fine, i think that's the trick
Best regards
Meam
Old 07-14-2002, 15:26   #10 (permalink)
Member: 11513
I have had same problem with 7110, lcd was black. I traing to change contrast using windls, nkprofile but contrast no changed, so I changed the lcd and phone works fine
Best Regards
Komarus
Old 07-19-2002, 03:13   #11 (permalink)
Member: 13142
But before change Sortware, was all good. So I think, that Problem is with Software, not wit LCD
Old 07-19-2002, 04:43   #12 (permalink)
Member: 11513
E-mail me to coma@v-lo.krakow.pl or GG: 3962390
(mysle ze sie jakos dogadamy )
Pozdrawiam
Best Regards
Komarus
Old 08-04-2002, 17:44   #13 (permalink)
Member: 13142
I have tried Your's solution but without success - the LCD is still to bright
Old 08-05-2002, 14:33   #14 (permalink)
BufferMess's Avatar
Member: 9856
Nokia Profile Utility works good for LCD contrast adjustments. Every time you adjust it make phone restart.
If it does not work, you should reflash good eeprom.
Best Regards
Sean Archer
Old 08-12-2002, 22:27   #15 (permalink)
nsm-1's Avatar
Member: 11416
Hi,
I encountered exactly the same problem with a 5.01 full flash (PPM H I believe) I downloaded from somewhere in the net. The problem is that the contrast value in the EEPROM part is incorrect.
It can definitively be fixed using Nokia Profile 1.17 running under Win 9x (I tested 95, 98). Nokia Profile is an addendum to Logo Manager and uses interface settings etc. from this program, so first of all install and configure Logo Manager properly.
problem with contrast 1110i after unlock shayan744 Universalbox 2 02-26-2007 05:18
Help with contrast in Siemens C45 NetSpider x1x to x45/x50 7 05-10-2003 21:59
C35 problem with contrast vva x1x to x45/x50 4 10-01-2002 14:36
problem with net in 5130 v 5.71............. gladeo Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 04-29-2002 02:14
Problem upload MCU&PPM in 7110 fyd Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 01-06-2002 22:19
Page generated in 0.35897 seconds with 11 queries
