09-15-2001, 09:37 | #1 (permalink) |
Major Poster Join Date: May 2001 Location: Netherlands
Member: 4478 Status: Offline Thanks Meter: 0 | Problem with N3310 Telfort 4.18, Please help if you have this phone! I have here a Telfort N3310 probably version 4.18... He's dead.<br />(Then there is no way to check the version, is it? --> It's bought in February/March)<br />It's dead because some bright soul flashed it from 200000 to 210000 (instead of 270000) I have the full repair flash here (200000 to 300000) but is this also compatible for Telfort phones? <br />(the partial is different, so maybe the repair flash should be different too).<br />If it isn't compatible, can someone please send me a little backup from N3310 Telfort V4.18 200000 to 220000 <br />(that will be enough, I have repaired more Nokias this way). Thanks a lot!<br />Chantal<br />[email protected] |
09-16-2001, 01:22 | #3 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Portugal Age: 49
Member: 6156 Status: Offline Thanks Meter: 3 | I wouldn't use the 200000-300000 repair file...<br />Do the following...<br />Read the full flash and search the flash for the version... If it was flashed from 200000-210000 then compare 210000-220000 with one the same address space taken from a non-telford (same sw version).<br />If it matches (you might be lucky) just flash that bit (cut the file to fit, of course). Don't flash more than the necessary!!! 200000-300000 probably has PPM data (don't recall it now)... and that certainly won't do! |
09-16-2001, 04:27 | #4 (permalink) |
No Life Poster Join Date: Oct 2000
Member: 2274 Status: Offline Thanks Meter: 0 | Firmware is from 0020-0033! Just flash firmware backup of any 3310-418 and after that flash telfort partial! Phone will work! Greetings MR... [ 16 September 2001: Message edited by: Brobble ]</p> |
09-16-2001, 10:19 | #5 (permalink) |
Member: 4478 Status: Offline Thanks Meter: 0 | Unfortunately my backup of 20000 to 30000 was empty, so I can't retrieve the firmware anymore...<br />I tried three backup files (from 200000 to 300000) version 406, 418, 424 but the phone just won't turn on :-(<br />Nothing happens, so this means I really need a backup from a Telfort phone?<br />Can someone please send it to me?<br />(406 or 418) from 200000 to 3000000 Thank you!<br />Tal<br />[email protected] |
need help if you have | vino_89 | Nokia Base Band 5 ( BB-5 ) | 3 | 02-09-2010 08:05 |
NOKIA 7610 please help if you can | TANGOO | Nokia Hardware & Hardware Repair | 5 | 10-25-2007 07:06 |
Problem With My N80 Please Help If You You Know How | majestic36 | Nokia Base Band 5 ( BB-5 ) | 10 | 08-09-2007 21:10 |
Please help if you can | auth_repair_cen | GSM Programming & Reverse Engineering | 4 | 12-30-2005 14:34 |
Please help...if you knows the solution.... | needi | BF, BG, TH, BHx Series | 1 | 09-02-2003 00:37 |
