Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 06-27-2000, 09:56   #1 (permalink)
Member: 1462
Unhappy Problem with nokia 5110!
I have a problem with reading a nokia 5110 phone. I tried to read the phone with
UNLOCK NOKIA 3210 VER 5.31 BY ******** but the program can not read the phone.
The program give "phone not connected" and I tried everything.
I used a data cable (DAU-09) and my phone is REALLY ON when I run the program.
Can someone help me?
Old 06-27-2000, 10:21   #2 (permalink)
Registered User
Member: 788
Post
Did you check your cable you must have m-bus cable not (data) serial rt,tx then you can unlock normaly.
Regards
Sebastijan
Old 06-27-2000, 11:49   #3 (permalink)
Member: 1462
Post
How can I verify that the cable is m-bus?
On the cable it said:
TYPE : DAU-09 (APPLY: NOK51xx/61xx)
my version is : nokia 5110 v5.23
[This message has been edited by Snowball (edited 27 June 2000).]
Old 06-29-2000, 06:38   #4 (permalink)
MDR
Member: 1272
Thanks Meter: 3
Post
your phone connector, when opened should have four wires, if it only has 3 wires, then its not an mbus/fbus cable but only an fbus cable.
get an mbus cable.
Old 06-29-2000, 08:03   #5 (permalink)
Member: 1480
Wink
Could you send me SW for 3210 5.31 by ********.
tnx
Old 06-29-2000, 17:08   #6 (permalink)
Registered User
Member: 788
Talking
You can download free from www.********.com (exchange software)
Works 100%
Regards
Sebastijan
********@********.com
Old 06-30-2000, 16:25   #7 (permalink)
Member: 827
Angry
How can you say the software works for 3210v5.31? The software you give away for free is Nokia Tool v0.33 by Pro and I swear it doesn't work with 5110v5.28 and 3210v5.31.
Don't tell me my software doesn't work or my cable is not an MBUS etc. coz I can unlock phones other than these phones you claim that you can unlock.
You've also shown a diagram shorting the flash chip. Can you give us the technical specs of the flash so we can check if it is safe to short the pins you said to be shorted?
Works 100%
Regards
Sebastijan
Old 06-30-2000, 21:11   #8 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 601
Post
To Wildswan,
Nokia Tool .33 or any version can unlock
new nokias but with trick of shorting EEPROM
24C16 (8pins) and not Intel Flash. It can
unlock if you follow intructions. I tested it
myself, only I have problem afterwards I
do not blame the solution. Maybe its because
I've been playing with the unit for too long
with many softwares and now comes a solution
that works, my unit was already acting
crazy because of previous experiments. If you
short SCL(6) and pin7, the phone will not
be damaged, (even if it is power on), only
the phone cannot get correct responces from
EEPROM. I think this is the reason why it
can be tricked and so can be unlocked.
Best Regards,
X-Shadow
Old 07-01-2000, 07:09   #9 (permalink)
Member: 827
Smile
I just have a phone to try this solution with. I just don't know if it will still work since the owner already locked the other 3 locks.
Originally posted by X-Shadow:
To Wildswan,
Best Regards,
X-Shadow
I need protocols for sending/receiving SMS and data with NOKIA 5110 over a serial cab SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-18-2001 17:33
problems with 8850 , 5110 5,29 , 3210 6 ... ??? makona Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 01-08-2001 05:48
Problem with Nokia 5110 Ola mashco Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-31-2000 23:42
Still with nokia 5110 ver 5.24 VirtualM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-11-1999 18:57
PROBLEMS CHANGING NOKIA 5110 IMEI Salty Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-22-1999 20:22
Page generated in 0.34455 seconds with 8 queries
