Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 11-12-2000, 14:25   #1 (permalink)
Member: 2084
Question to robby... scheme for pony programmer?
do you have the scheme that can be use for pony prog, can u share it to us?
thanks
Old 11-12-2000, 14:32   #2 (permalink)
Member: 2566
Post
me too or post the url on the forum
Thnx Soldeer@hotmail.com
Old 11-12-2000, 15:25   #3 (permalink)
Member: 2566
Post
I found a programmer at http://www.jdm.homepage.dk/newpic.htm
But i don't know if it workd with pony prog. I don't heave this prog can you mail it to me????
Old 11-12-2000, 16:35   #4 (permalink)
Member: 1920
Post
hi
i made very very very simble diagram
work on all 24Cxx with pony prog
email me
free for you and all
Old 11-12-2000, 18:41   #5 (permalink)
VIP-Member
Member: 254
Post
Hello to all
Ok everybody how wants schematics for PonyProgramer please email me private.
I have tested 100%
It is two very analysed schematics and one html list of materials.
My regards to all.
Robby
Old 11-12-2000, 19:27   #6 (permalink)
Member: 1920
Post
MY schematics
CONSIST OF
3 5V1 ZDIODE
2 4K6 RESITORES
1 78LSO5 VOLTAG REGULATER
2 100n CABSTERS
WORK 100% ON ALL 24CXX
Old 11-12-2000, 19:50   #7 (permalink)
Member: 1920
Post
please if any one know
i need good schematic and programer for:
27Cxx Parallel Flash memory (computer Bios)
tanx
Old 11-13-2000, 09:33   #8 (permalink)
X-Shadow's Avatar
Member: 871
Post
To AMTX99,
Why 3 5V1 ZDIODES? I think you only need two,
one at line going to PIN5 and another at
line going to PIN6. You don't need it at
line to PIN8 because it is already regulated
by you 78LS05 I think we use same scheme,
but my values are different like 10K instead
of 4K6 and 4.7V instead of 5.1V zeners...
I will try to make another EEPROM Porgrammer
using your values tonight and compare... Your
values sound better, especially for the 5.1
zeners. Thanks...
Best Regards,
X-Shadow
Old 11-13-2000, 19:43   #9 (permalink)
Member: 2566
The full scheme is at the help of UPSU 4.2!!! Also the pony program you can download it at gsmgods.net (great site good work)
Old 11-14-2000, 01:02   #10 (permalink)
Member: 1920
Post
To X-Shadow
i dont found your email adress
email me ..i well send you may schematic
About the 5V1 ZDIODE it is after 78LS05
yes you can remove it .
reg
Old 11-14-2000, 08:47   #11 (permalink)
X-Shadow's Avatar
Member: 871
Post
Hello Guys,
Today I tried to read EEPROM from 3210 5.36
and 5110 5.29, I did not succeed! I had to
totally remove the EEPROM with hot air solder
because removing just pin 1 2 3 4 (GND) did
not work!
I am sure that previous versions lower than
the mentioned aboved can be read without
removing EEPROM from phone. But now using the
same interface that I've been using fo years
now, it doesn't work anymore...
I amde some tests (continuity test using
multi-tester) and noticed that the readings
for pin 8 and Pin 5 are higher on 5.36 and
5.29 compared to a 6138 5.01 and a 6150 4.13!
Maybe this is the problem. All pins readings
like on PIN 1 2 3 4 6 7 are the same. I am
sure that nokia made modifications to the
EEPROM layout which makes it harder to
prgram on board even with external power
(charger) attached to the PCB. Now I always
get error 14 or error 11 at Pony Prog 2.01a.
To AMTX99,
If you have successfully worked with these
versions, please share me your info...
Best Regards,
X-Shadow
sid67b@anytimenow.com
Old 11-14-2000, 08:58   #12 (permalink)
Member: 1920
Post
hi
two days ago I read EEPROM from 5110 5.28
by removing just pin 5 and its work
I have tody 3210 ver 5.36
I well try it tody...
Old 11-14-2000, 13:58   #13 (permalink)
VIP-Member
Member: 254
Post
Hello guys I don't know why you have problems with reading 3210 eeprom.
I am using Pony maded from Daniel (Uspu).
And I am reading/writing direct from PCB all version, 5.31, 5.36, 6.0. of Nokia 3210.
But X-Shadow you have made me crazy
9 hours I spend to unlock one 3210 v 6.0 with your subscriptions (3) with no result.
Are you sure ?
With my best wishes to all of you
Regards Robby
Old 11-14-2000, 19:42   #14 (permalink)
Member: 2463
ok - removing pin5 and reading serial eeprom with eprommer.
But now, what to do with this hexdata? Which Byte(s) should be changed to remove simlock. Or is it possible to read correct unlock code for #pw+9999999999+1#??!
Old 11-15-2000, 13:46   #15 (permalink)
Member: 1920
Post
to Diddl
many phones like philps .can be unlocked only by eeprom soulation ..
but in nokia ,,,you can use the cabel..
reading eeprom before unlocking
to rest you phone again ..if you get contact
servic ,,,after unlocking ..
olso to repaire your phone if you alrady have contact serv. in your phone
read the old messages about this problems
reg
pony programmer and xprog programmer instull help ARAB GSM CAR Electronics 2 06-02-2007 16:48
Schematics For Pony Programmer tnsupplies Universal GSM Software 1 07-19-2003 16:58
Hi sombody can help me with pony programmer CHATAR Universal GSM Software 2 04-14-2002 10:25
Pony programmer wanted kage Main Sales Section 7 01-10-2002 12:24
I want to buy Scheme for TAU tited Main Sales Section 0 10-09-2001 04:24
Page generated in 0.34117 seconds with 11 queries
