Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210 |
| | #1 (permalink) |
| Junior Member Join Date: Oct 2004 Age: 28
Member: 89102 Status: Offline Thanks: 0
| Security code in 8110/3110 Hello I'm looking for security code fo nokia 3110/8110. I was trying 12345 but it isn't correct. Thanks for relpy |
| The Following 10 Users Say Thank You to matysz For This Useful Post: |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2005 Age: 33
Member: 137735 Status: Offline Thanks: 0
| TAC FAC SNR SP TAC = Type approval code FAC = Final assembly code SNR = Serial number SP = Spare *#7780# restores Factory Settings..(Memory, language, counters not included) *#3110# for checking the phone's software (SW) - called firmware revision information. #746025625# [*#sim0clock#] Checks if the sim clock can be stopped. Sim clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59. *#92702689# [*#war0anty#] Press the following warranty code: 6232 (OK) : Displays the Month and Year of Manufacture (0997) 7332 (OK) : Displays the date of the last repairment - if found ('DATE NOT SAVED'...) 7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...) 9268 (OK) : Displays Serial Number 37832 (OK) : Set the Purchasing Date MMYY (Warning: You can only do this once - So be careful ...) 87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another Service Prover Lock The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it! The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for upto 4 different providers. But most phones with restriction only have one lock activated. ( lock 1) The main code used in Nokia phones is: #pw+(master code)+Y# This code is able to check, activate or remove Sim card restriction (SP-lock). Use the * key to get the p, + and w chars. 'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with. #pw+1234567890+1# for Provider-Lock status #pw+1234567890+2# for Network-Lock status #pw+1234567890+3# for Country-Lock status #pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS W = PRESS "*" THREE TIMES P = PRESS "*" FOUR TIMES + = PRESS "*" TWO TIMES MASTERCODE = 1234567890 Y = NUMBER 1 TO 4 (master code) is a 10 digit code, based on the phones IMEI number. (I can NOT give you the master code - SO DON'T ASK ME FOR IT !!!!!!!) Eg. To remove restriction on lock 1 type following code: #pw+(master code)+1# If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code) eg. To check if phone if restricted on lock 1 type the following code: #pw+1234567890+1# Please NOTE that these codes could be used with care! A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful! Bypass the SP lock With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIMlocked to one privider you can bypass the SP lock like this: 1: Insert sim card of diferent provider. 2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE? 3: Press the "C" key. 4: Then Press * and wait until it desapear and apear again, then press * one more time and 04*PIN*PIN*PIN# The phone now says: PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option ! Fast silent mode In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #. The 54# Tip: Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed dialing. |
| The Following 12 Users Say Thank You to calmant224 For This Useful Post: |
| | #4 (permalink) |
| this phone ask me about security code when i turn him on so a cannot do anything more ;/ |
| The Following User Says Thank You to matysz For This Useful Post: |
| | #7 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 1999 Location: spain
Member: 122 Status: Offline Thanks: 0
| Hi. Ohhh my friend, see here: Quote:
Solution here: need security code for nokia 1100 Bro. | |
| | #13 (permalink) | |
| Hi. Quote:
N-box, Twister, JAF, PBB, .... But no response me, that model is your nokia? For one phone, buy a box :/, box many €€€. Bro. | |
| The Following User Says Thank You to Phreackgsm For This Useful Post: |
| | #14 (permalink) | |
| Junior Member Join Date: Oct 2005 Location: united states Age: 41
Member: 186946 Status: Offline Thanks: 0
| 8310 Quote:
| The Following User Says Thank You to ebrim-41thcma For This Useful Post: |
| | #15 (permalink) |
Member: 192911 Status: Offline Thanks: 0
| HI i want the code for motoRacer game. my IMEI :356665000270116 nokia 6600 please help me |
| The Following User Says Thank You to sozana For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| when entering code in 8110, it says usim alreay unlock | ashvin | LG | 6 | 09-11-2005 22:33 |
| Resetting security code in 8110/8120 | fonedoctorjnr | LG | 5 | 01-27-2005 00:09 |
| HOW TO RESET SECURITY CODE IN NOKIA 6210 | ed2k_7 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 10 | 05-26-2001 05:33 |
