10-19-2001, 11:46 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: London Age: 41
Member: 5006 Status: Offline Thanks Meter: 2 | SIM CLONING PROBLEM However i get the menu, select the com port and then press enter, then what happens is it comes with the error msg something like "can't send msg to reset card". Any ideas on what i can do. Thanks in advance. |
10-19-2001, 12:18 | #2 (permalink) |
No Life Poster Join Date: Jan 2000
Member: 860 Status: Offline Thanks Meter: 1 | Have you put your programmer in smartmouse mode, and used setting for 3.56 MHz? If not try this prog:<br /><a href="http://www.adteknik.se/software/ElvisCC.zip" target="_blank">http://www.adteknik.se/software/ElvisCC.zip</a> 1st. Use the prog ElvisCC turn on your Elvis programmer.<br />2nd. Using the prog ElvisCC Set your Elvis programmer in smartmouse mode.<br />3rd. Run Install.bat from the sim_scan dir.<br />4th. Select your com port.<br />5th. Use 3.56 MHz setting.<br />6th. Good luck! Best regards! |
In lg rd2230 tata sim cloneing problem | laksh007 | Various CDMA/TDMA Cell Phones | 0 | 02-11-2010 19:53 |
SIM Clone 16in1 problem | shaqa | Sim Cloning and Scaning | 0 | 03-07-2009 14:13 |
SIM Clone WEBSITE>< Download Cloning Guide | GSM Solutions Ireland | Sim Cloning and Scaning | 13 | 09-24-2004 16:30 |
SIM-Cloning with FunCard, GoldCard & out-of-date SIM | misschehrazad | Sim Cloning and Scaning | 4 | 04-27-2004 18:08 |
sim clone problem!!! pls hlp me | gsm-lord | Sim Cloning and Scaning | 9 | 03-12-2002 08:27 |
